How To Fix Samsung Galaxy S5 SM-G900F Dead Boot This Guide will help you to fix your Dead Boot Samsung Galaxy S5 SM-G900F device, The dead boot problem may happen to anyone and because of many reasons, But that is not important, The most important thing is to know how you can revive the Dead Galaxy S5 SM-G900F and bring it to work again, In this guide we will show you the easiest way to perform the this repair operation by yourself. There's no need for any special or expensive tools to fix the dead Galaxy S5 SM-G900F device, You have to repair and get the following: - Working Samsung Galaxy S5 SM-G900F mobile phone. - Odin3 Flasher. - 4GB SDHC MicroSD card. - MSM8974PRO_boot_recovery.pit - Normal Bootloader file: BL_G900Fxxxxxxxx_...tar Samsung Galaxy S5 SM-G900F Dead Boot Repair Steps: - Run Odin3.exe flasher. - Click on PIT button and select: MSM8974PRO_boot_recovery.pit - Click on BL button and select: BL_G900Fxxxxxxxx_...tar - Check T Flash option at Odin3 flasher. - Insert the microSD card inside a working Galaxy S5 SM-G900F mobile phone. - Put the working Galaxy S5 SM-G900F mobile phone into Download Mode, Read this Guide for help. - Connect the GS5 mobile phone to the computer using the USB cable. - When Odin3 flasher detects the device, Click on Start button. - After Odin3 do his job, You will get the PIT and Bootloader files on the microSD card. - Remove the microSD card from the working GS5 and insert it inside the Dead Galaxy S5 mobile phone. - Press and Hold the Volume Down key + Home key + Power key. - If the recovery process completed successfully, You will get the dead Galaxy S5 device into Download Mode. - Now you have to flash your device with full firmware package, Pit, Bootloader, AP, CP, And CSC files. Firmware : http://forum.gsmhosting.com/vbb/f200...wares-1813265/ |
that sounds easy. where can we get these files - MSM8974PRO_boot_recovery.pit - Normal Bootloader file: BL_G900Fxxxxxxxx_...tar |
Galaxy S5 Firmware Version Using Odin3 ? |
regards |
SIR I NEED MSM8974PRO_boot_recovery.pit - Normal Bootloader file: BL_G900Fxxxxxxxx_...tar |
http://s2.subirimagenes.com/privadas...255s5-root.png |
Its useless unless you get those files. |
how we can repait bootloader if we dont have those files? |
Can this same procedure be used for a G900h??? Hi All, please can someone confirm for me or otherwise if this procedure for unbricking the g900f will work for my g900h??? i have my suspicion it may work but don't want to take chances and more importantly, i have i don't have another working g900h but rather a g900t. can i creat those two files with the g900t and write it to my g900h???? thanx in advance for your kind assistance. |
Files for flashing Use this files for it. Reply if it works for you. |
copy paste from tsar 3000.there is no use for that |
please files MSM8974PRO_boot_recovery.pit BL_G900Fxxxxxxxx_...tar |
I have the files in mediafire but it wont let me post it here. |
sir can you pm us the link.tia |
