Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
02-03-2013, 21:32 | #6 (permalink) | |
No Life Poster Join Date: Sep 1999 Age: 54
Member: 521 Status: Offline Thanks Meter: 76 | Quote:
I've tried all the flash files with no pit file and solved the problem but I tried it with box but I solved the problem of the phone came to me in broken service so I do not know what the customer | |
03-17-2013, 20:32 | #9 (permalink) |
Freak Poster Join Date: Jul 2004 Age: 42
Member: 71363 Status: Offline Thanks Meter: 7 | Firmware Update Steps: 1-Run Samsung I9003 Galaxy SL Down-loader. 2-Check Re-Partition, Auto Reboot and F. Reset Time. 3-Click PIT button and select this file: latona_20110114.pit 4-Put your phone into download mode: Press Volume down + OK + Power. 5-Connect USB cable and the program will detect the phone's Com number. 6-Click Start button to download the PIT file to phone. 7-After it is Done Click on Reset button, then UN-select Re-Partition box. 8-Click PDA button and select this file: I9003xxxxx-xxx...-PDA-low-CL890053.tar.md5 9-Click PHONE button and select this file: MODEM_I9003xxxxx_REV_00_CL889972.tar.md5 10-Click CSC button and select this file: GT-I9003-CSC-xxxxxx.tar.md5 11-Remove the battery, then enter Device into Download Mode again. 12-Click Start button to flash these files to phone. 13-Do not touch anything till you see PASS on the program window. 14-Do full reset by this Code: *2767*3855#. Samsung I9003 Galaxy SL Original Firmware's Last edited by ...:::::NP™:::::...; 07-26-2017 at 01:53. Reason: Link correction |
The Following User Says Thank You to clinique_gsm For This Useful Post: |
