for csc unknow you need to write efs file in pda tab but after write efs you imei is restore means 0049909778989 like this then you neeed to repair it on z3x 16.1 virsion :D Enjoy :::::::::Hussain::::::::;) |
I did the procedure with the up-side-down download mode, but now the phone turns on and has NULL IMEI, is there a fix for that? |
hello friends i also facing same problem in GT-i9300 pls anybody sloved this issue pls help me> |
Note 2 GT-N7100 Flashing stock rom 4.3 with odin but no signal EMEI and S/N are correct. |
Just check one package in the options and choose any firmware with PDA only and check mark on safe flashing and on efs repair check default efs then your problem will solve( May you need to make reset factory settings by recovery mode) Off course after this step you need to repair imei and S.N by this tool I have solved more than 10 by this tool |
<OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> CODE_I9300XXDLJ4_368423_REV00_user_low_ship.tar.md 5 is valid. <OSM> MODEM_I9300XXDLID_REV02_REV04_CL1188619.tar.md5 is valid. <OSM> CSC_UBL_I9300UBLDLJ1_CL396125_REV00_user_low_ship. tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> All threads completed. (succeed 0 / failed 0) <ID:0/050> Added!! <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> CODE_I9300XXDLJ4_368423_REV00_user_low_ship.tar.md 5 is valid. <OSM> MODEM_I9300XXDLID_REV02_REV04_CL1188619.tar.md5 is valid. <OSM> CSC_UBL_I9300UBLDLJ1_CL396125_REV00_user_low_ship. tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/050> Odin v.3 engine (ID:50).. <ID:0/050> File analysis.. <ID:0/050> SetupConnection.. <ID:0/050> Initialzation.. <ID:0/050> Set PIT file.. <ID:0/050> DO NOT TURN OFF TARGET!! <ID:0/050> Get PIT for mapping.. <ID:0/050> Firmware update start.. <ID:0/050> sboot.bin <ID:0/050> NAND Write Start!! <ID:0/050> <ID:0/050> Complete(Write) operation failed. <OSM> All threads completed. (succeed 0 / failed 1) |
