Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
03-21-2014, 12:41 | #1 (permalink) |
Freak Poster Join Date: Dec 2007
Member: 661195 Status: Offline Thanks Meter: 31 | N7100 stuck at samsung logo product name:GT-N7100 CUSTOM BINARY DOWNLOAD:NO CURRENT BINARY:OFFICIAL SYSTEM STATUS:OFFICIAL I try sd card method.Tera term showing PMIC rev = PASS2(4) mmc_initialize: mmc->capacity = 30777344 þ +UART READY after nothing.is Emmc chip error?solution please. can someone upload N7100 multiple firmware package. Thanks, [email protected] |
03-21-2014, 19:03 | #3 (permalink) |
Freak Poster Join Date: Dec 2010 Location: i love my india Age: 33
Member: 1476841 Status: Offline Thanks Meter: 201 | 1.....software 2,,,efs repair 3.emmc ic repair by gpg ya atf box same p[roblem final change emmc ic |
The Following User Says Thank You to hand2hand For This Useful Post: |
03-21-2014, 19:32 | #4 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | 1. Has the phone been rooted or modified in any way? 2. Are you running a custom rom? 3. Were you flashing something when this happened? 4. Or is the phone 100% stock? 5. And lastly did you try charging it while off with the OEM charger and cable until the LED light turns green? |
03-21-2014, 19:36 | #5 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | First, if you are rooted, I HIGHLY ADVISE you to make a backup ROM (see How to Make Backup ROM). And after making backup ROM, do MAKE A BACKUP of your internal storage by copying everything to your hard disk. If something goes wrong, you will be able to do a factory reset in stock Android recovery and get all of your settings, apps, photos, and videos back. Also, if you are on a ROM like CM10, AOKP, or any ROM that’s non-Samsung, non-TouchWiz, you will definitely need to do a factory reset. You can also do a factory reset in CWM Recovery BEFORE unrooting, that will not erase the contents of your internal storage (then you can skip the backups). If you are returning your phone for warranty, run Triangle Away app before unrooting, that will erases any traces of root. (Also installing a stock firmware DOES NOT increase binary count.) This method is using ODIN and Windows computer. If you have Linux or Mac computer, you can also use Mobile ODIN PRO (on Play Store) to do the same thing. Unroot/unbrick your Galaxy Note 2. Go to either Samsung-updates or SamFirmware and download a compatible stock firmware for your Galaxy Note 2. For example, if you have the international Galaxy Note 2, search for model GT-N7100 and download the appropriate firmware for your country. If your country firmware does not exist you can use one that’s close to it, these firmwares will work on all GT-N7100. And flash again with odin |
