Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
02-13-2012, 09:57 | #1 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: yes
Member: 420658 Status: Offline Thanks Meter: 211 | WinComm I have found "only" WinComm2009.zip... Quote:
Thanx in advance. Best Regards | |
11-23-2012, 09:36 | #3 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | S8000 Jet work with WinComm... S8500/S8530... too. Sorry. I have not all Samsung and maybe only the older ones... Here an example of WinComm Logging... Send Command FmPrtShpMemorymap to handset and it will answer: Code: _SHP_FOTA is enabled. FLASH_FOTA_HOLE_RESERVED_SIZE : 0X00200000 FLASH_FOTA_ENGINE_SIZE : 0X000C0000 FLASH_FOTA_DELTA_SIZE : 0X00240000 FLASH_ERASE_SECTOR_SIZE : 0X00020000 NAND_FLASH_ERASE_BLOCK_SIZE : 0X00020000 NAND_FLASH_READ_PAGE_SIZE : 0X00000800 FLASH_USBBOOT_START_ADDR : 0X00000000 FLASH_CODE_START_ADDR : 0X01100000 FLASH_CODE_END_ADDR : 0X03700000 FLASH_CODE_COMPRESS_START_OFFSET : 0X00000800 FLASH_RO_END_ADDR : 0X02000000 FLASH_RSRC1_SIZE : 0X04B00000 FLASH_RSRC1_START_ADDR : 0X03700000 FLASH_RSRC1_END_ADDR : 0X08200000 FLASH_FOTAENGINE_START_ADDR : 0X08200000 FLASH_FOTA_DELTA_START_ADDR : 0X082C0000 FLASH_RSRC2_START_ADDR : 0X08500000 FLASH_RSRC2_END : 0X086E0000 FLASH_FACTORY_FORMAT_CHECK_BASE : 0X086E0000 FLASH_FILESYSTEM_VOL1_START_ADDRESS : 0X08500000 FLASH_FILESYSTEM_VOL2_START_ADDRESS : 0X08700000 FLASH_FILESYSTEM_VOL2_SIZE : 0X07140000 NANDMAP_VIRTUAL_ADDR_BASE : 0X40000000 FLASH_FACTORYFS_BASE : 0X48700000 FLASH_ROM_WRITABLE_ADDRESS_MAX : 0X0DC00000 FACTORYFS_AREA_LEN : 0X05500000 FLASH_ADDRESS_MAX : 0X10000000 FLASH_BAD_RESERVED_BLOCK_NUM : 0X00000028 FLASH_SECURE_DATA_SIZE : 0X00200000 FLASH_FILESYSTEM_UMS_PARTITION_SIZE : 0X00000000 ==Partition Information===================== Partition Name : [Start Block] [Total Block Number] COPIEDOS : [136] [120] USER_DEFINED_RW : [256] [808] TFS4 : [1080] [907] SFS : [1987] [16] ==Reservoir============================ Name : [Start Block] [TotalBlocks] ERL : [2003] [1] REF : [2004] [1] UPCB #1 : [2005] [1] UPCB #2 : [2004] [1] Bad block reserved Pool : Total reserved block number is Invalid between ShpMemoryMap.h(40) and Xsr2ONLD.cpp/Xsr2PNLD.cpp(41). LPCB #1 : [2046] [1] LPCB #2 : [2045] [1] *> return value = 1 (0x00000001) Command list is long... you can find few in apps_compressed.bin Best Regards |
