Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
02-21-2015, 05:50 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: TELANGANA
Member: 1175976 Status: Offline Sonork: dgr Thanks Meter: 38 | SAMSUNG gt-e2252 restart log Look inside the Flash Loader folder, You will see: Sunstone_V5_00_0_1_WHQLed.zip extract it too. - Run bfloader.exe program. - Click on SET Model button to select: E2252_Utica_Setting_v00_production.mdl - Click Main Partition button. - At the opened window click on Browse button to select E2252XX.ptt file from the extracted firmware BIN folder, Then click OK. - Click CSC button. - At the opened window click on Browse button to select E2252XX.ptt file from the extracted firmware CSC folder, Then click OK. - Click on START button. - With battery inside the turned off phone Press and Hold 1 + 3 Keys then plug the USB cable to it. - When Windows Asks you for Drivers browse to Sunstone_V5_00_0_1_WHQLed folder. - When Flash Loader program detects your phone it will start to install the firmware files into your device. - After Flash Loader finishes his job you will see "Slot freed for new download" - Disconnect the USB cable from it. - Turn on your Samsung E2252. - Do full reset using this code *2767*3855# - After rebooting your phone will be ready to use. i tried this way completed but same problem share any solution urgent plz? |
