Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
08-26-2018, 23:32 | #1 (permalink) |
No Life Poster Join Date: Apr 2014 Location: Worldwide
Member: 2174901 Status: Offline Sonork: 100.1671257 Thanks Meter: 1,248 | Samsung NOTE 9 100% Working [FRP][RESET][SOLUTION] !!! As usually, HalabTech_Team Have the fastest Solution In Gsm Market. Today We provide Frp Reset For NOTE 9 Free For all GSMHOSTING MEMBER ===================>0<== ================== First Of All, You need Combination files Download From Here: N960F N960FD Here N960U Here N960U1 Here ===================>0<== ================== Second, You need Firmware Download From Here: N960F N960FD Here N960U Here N960U1 Here ===================>0<== ================== Firmware un-rar pass:- halabtechteam ===================>0<== ================== STEPS: 1. Flash Combination 2. Go and enable Oem From setting 3. Flash Firmware All Done Halabtech_Team |
The Following 21 Users Say Thank You to hosam kashto For This Useful Post: |
08-26-2018, 23:35 | #2 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Canada Age: 44
Member: 169896 Status: Offline Thanks Meter: 323 | Thanks but u missed the factory reset step in combination firmware Sent from my SM-G965W using Tapatalk |
The Following 2 Users Say Thank You to ashahzad_pk For This Useful Post: |
08-27-2018, 07:26 | #3 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Always keep spam free, good work, thank you post, unnecessary word will be removed without any notice. Reserve for Update Bit firmware and combination sync files will be updated only for Note 9. when it is will be officially released from Samsung.
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
The Following 3 Users Say Thank You to ...:::::NP™:::::... For This Useful Post: |
10-17-2018, 06:41 | #4 (permalink) |
No Life Poster Join Date: Jun 2006 Location: united states
Member: 296215 Status: Offline Thanks Meter: 56 | hi friends, back, I managed to make the frp to this verizon model, 1 - flash this combination, COMBINATION_FAC_FA81_N960USQU1ARG4_FACFAC_CL140838 94_QB19146898_REV00_user_mid_n ship_MULTI_CERT Halabtech.tar 2 - reset from the combination ,,, 3 - flash this firmware, N960USQS1ARH6_N960UOYN1ARH6_VZW done ... 100% tested br |
The Following 2 Users Say Thank You to ffhfox For This Useful Post: |
11-02-2018, 17:07 | #6 (permalink) |
Freak Poster Join Date: Jun 2011 Location: bruteforce locale
Member: 1589112 Status: Offline Sonork: 1618000 Thanks Meter: 139 | any one have sulotion for n9600z COMBINATION_FAC_FA81_N9600ZCU1ARG4_FACFAC_CL140838 94_QB19149726_REV00_user_mid_noship_MULTI_CERT.tar this combination is blocked by frp thanks |
11-02-2018, 18:15 | #7 (permalink) | |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Quote:
http://forum.gsmhosting.com/vbb/f777...6-5-a-2491392/ http://forum.gsmhosting.com/vbb/f777...vices-2488204/ | |
The Following 2 Users Say Thank You to amleto90 For This Useful Post: |
11-02-2018, 23:06 | #8 (permalink) | |
Member: 1589112 Status: Offline Sonork: 1618000 Thanks Meter: 139 | Quote:
great!! done http://forum.gsmhosting.com/vbb/f777...6-5-a-2491392/ thanks to Amleto90 | |
11-17-2018, 17:25 | #10 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Samsung
Member: 10028 Status: Offline Sonork: n/a Thanks Meter: 840 | This method will also work on new Samsung - FRP Unlock/Bypass: G950U, G955U, G950F, G955F U5/BIT5/REV5 FRP bypass. Insert SIM card in phone, if 112 or 911 (Emergency number does not connect). No need FLASH No need COMBINATION No need to worry about Phone's Revision/Binary. Works on Android 7.1.1 - Tested Works on Android 8.0.0 - Tested Works on Android 8.1.0 - Tested Works on security patch level : September 01, 2018 Works on security patch level : August 01, 2018 Works on security patch level : July 01, 2018 Works on security patch level : June 01, 2018 |
The Following User Says Thank You to Mobile-Lab For This Useful Post: |
03-30-2019, 02:47 | #15 (permalink) |
Junior Member Join Date: Jun 2005
Member: 157223 Status: Offline Thanks Meter: 5 | after flashing Combination and resetting it fails when you flash the original firmware via Odin. any solution to flash the original firmware back? |
The Following User Says Thank You to mattrojan For This Useful Post: |
