Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
10-30-2009, 14:32 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: UNITED KINGDOM Age: 44
Member: 74415 Status: Offline Sonork: gsm.zone Thanks Meter: 339 | Samsung flash guide for s5230,s8000,s8300 by Darkforest on Oct.13, 2009, under Samsung Flash Guides ***Warning!*** Make sure your phone dose not have sim lock before you try and flash. Type *#7465625# and make sure the SIMLOCK is OFF, if it is ON you MUST take it to a shop and have it removed or you will freeze your phone! First thing to always remember, is BACK UP YOUR PHONE, Pictures,wallpapers,music, and any contacts you have saved on your phone. I am not responsible for any damage to you, your phone, computer, or lost of data in this process. This is a guideline intended for professional technicians. USE AT YOUR OWN RISK!!! What you will need: 1. USB cable that came with your phone. 2. New Samsung NPS Install this software first, it contains the drivers for your phone, and has every thing you need for backup. 3. Multiloader 5.56 4. New firmware —————————–Now you are ready to begin———————————– 1. Make sure Samsung PC Studio is installed and communicates with your phone. And unpack the firmware in a folder you can easily find it. 2. Remove the Sim and MicroSD from your phone and replace the battery. 3. MAKE SURE THE PHONE IS OFF AND NOT CONNECTED TO THE COMPUTER. 4. Pixon and JET users : Hold down the “Volume -” button on the left or right side differs, and the “Camera” button on the right, then press the “Power” button = all three buttons need to be pressed together. Your phone should start up into a red\blue on black bootloader screen.) For U900 While holding the no. 9 button on the phones key pad, tap the power button, the phone screen will come on black with a red stripe that says “Download” 5. Now run MultiLoader v5.56 6.Plug the phone up to the computer. ———————————Multiloader Steps—————————————— 1. Select the radio button Example: U900 MSM6275/MSM6280, FOR S5230 BRCM2133, FOR JET LSI6410 2. Select Boot Change 3. Full Download 4. Master rom 5. Then click Boot, and select the boot files from the unpacked firmware folder. 6. Select Amss **NOTE** You must also select “APPS” if you are flashing a “JET” **NOTE** 7. Rsrc1 8. Rsrc2(Low) Do not use (Mid).r2c. On the JET may there may only be one option (Warning! phone may not restart if you select mid) 9. Select the Factory FS file. ***FOTA and ETC fields are left blank.**** When you are done it should look like this. 10. Click the Port Search button, it will find your phone and show the com port is ready. 11. Click the download button and be patient, this will only take a few minutes to complete. 12. When it’s finished, it will show “ok complete”. 13. Unplug the phone from the USB cable, reinstall the sim and SD card. *** NOTE Some models and some will not, if yours does not restart at this point, take out the battery a few seconds then reinsert it. NOTE *** 14. Now with every thing is complete, You can perform a hard reset by typing *2767*3855# into the hand set (but not necessary.) 15. When the phone resets type *#1234# into your handset to check your new firmware ver. ***NOTE!*** If your phone fails the flash for any reason, DO NOT TRY AND RESTART IT!!!!! Restart the computer and try the flash again! YES YOU MUST RESTART THE COMPUTER AND FOLLOW MY PREP GUIDE (Beginners guide.) **NOTE** If your phone camera does not work after the flash: Our Moderator DF3 Provided this handy pieces of information. You need to perform the camera firmware update, Admin codes have been changed on recent FW: a. Type *#197328640# in the Idle mode, then you can reach the test mode. b. Select [6] Video c. Select [3] Camera Firmware update [Please Wait] will be displayed. Wait a few minutes then [Please Wait] will be changed to [SUCCESS] Thank you DF3 For your help! BR KARIM SOURCE:http://darkforestgroup.com/blog/?p=7 |
The Following 11 Users Say Thank You to KARIM GSM-ZONE For This Useful Post: |
12-17-2009, 13:50 | #2 (permalink) |
No Life Poster Join Date: Jan 2005 Location: Mobile Phone Repairing
Member: 108747 Status: Offline Sonork: 100.108643 Thanks Meter: 655 | i have one s8300t i write s8300 flash file but signal problem face.so i need s8300t firmware plz help if any one have. b.r bahri |
02-09-2010, 19:20 | #6 (permalink) |
Junior Member Join Date: Mar 2008
Member: 731904 Status: Offline Thanks Meter: 2 | There are a lot of firmwares on that site http://darkforestgroup.com/forum/ |
03-10-2010, 12:53 | #7 (permalink) |
Junior Member Join Date: Feb 2010
Member: 1232683 Status: Offline Thanks Meter: 0 | Hi i have a s8300 which was stupidly flashed with wrong firmware so doesnt boot at all, i know this phone is imei blocked so isnt worth doing but i have another one same model. that isnt blocked but the first phone is better condition can i swap imei from phone 2 to phone 1 if i get boot fixed on phone 1 |
06-06-2010, 16:16 | #8 (permalink) |
No Life Poster Join Date: Sep 2005
Member: 182006 Status: Offline Thanks Meter: 41 | HI I am new to Samsung flashing . Question ... if my phone works ok (this one is a gts3650 Genio ) and the only problem is a phone lock code do I need to do a full flash ? or is it posible to only flash the BOOTFILE .If so how do I set up v5.6 ? Any help appeciated Steve |
06-30-2010, 12:54 | #9 (permalink) |
Registered User Join Date: Dec 2004 Age: 52
Member: 97188 Status: Offline Thanks Meter: 4 | s8000 flash tested and works perfect... i had a samsung s8000, at phone start up it was asking for phone lock. flashed and now works perfect.. thankyou. brian in ireland |
The Following User Says Thank You to badbrian For This Useful Post: |
07-05-2010, 08:35 | #10 (permalink) |
No Life Poster Join Date: Oct 2006 Location: yaoundé (av kennedy)
Member: 361348 Status: Offline Thanks Meter: 635 | bro wheb i flash my s8000 which hang whith multiloader v5.54 or 5.56 i av this error: Download Start Ch[0] BootLoader 298.4KB OK[0.3s] Dbl 154.2KB OK[0.2s] Wait reset !! Amss 13739.8KB OK[13.9s] Error : Apps Write [6.7s] note that fon connect only in dowload mode when i put it in blue screen it not connect |
07-06-2010, 15:06 | #11 (permalink) |
Banned Join Date: Apr 2010 Location: Alhoceima
Member: 1282976 Status: Offline Sonork: www.rifgsm.eu.pn Thanks Meter: 28 | download from here Unlock software, repair and flash tools, service manuals, unlock codes ... |
11-19-2010, 18:51 | #14 (permalink) |
No Life Poster Join Date: Nov 2005 Location: work Age: 11
Member: 195993 Status: Offline Sonork: 100.1653595 Thanks Meter: 128 | flashed the s5230 with 3 diffrent flashes for estonian language packs now "camera failed" this handset is brand new? any solution plz? If your phone camera does not work after the flash: Our Moderator DF3 Provided this handy pieces of information. You need to perform the camera firmware update, Admin codes have been changed on recent FW: a. Type *#197328640# in the Idle mode, then you can reach the test mode. b. Select [6] Video c. Select [3] Camera Firmware update [Please Wait] will be displayed. Wait a few minutes then [Please Wait] will be changed to [SUCCESS] tried this but the options above dont key in2 handset menu??? regards THE KOP... |
02-21-2011, 15:55 | #15 (permalink) |
Product Supporter Join Date: Jul 2010 Location: MobilesFactory,trichy,TN,India Age: 33
Member: 1347585 Status: Offline Sonork: 100.1596390 Thanks Meter: 467 | what about s5233a camera failed after flash ? this procedure not work i can't saw any video categary |
No flash files for S5230 | mobi786 | NSPRO | 10 | 02-11-2010 02:21 |
Need flashing guide for Samsung D900i | DeiViz | Samsung Flashers, Software, Firmware. | 0 | 11-02-2007 15:01 |
Total FLASH guide for DUMMIES | merten3000 | Samsung Flashers, Software, Firmware. | 5 | 09-22-2005 13:54 |
Setool3 LG 8180/8330 Flashing Guide for N00b's | hunk4004 | LG | 25 | 06-20-2005 16:10 |
SAMSUNG flash files for a200/300 , r2xx, n200, n100 , q105 ??????? | PTR999 | VLSI, Conexant, Skyworks and Old Models | 3 | 09-15-2002 21:04 |
