Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
04-29-2009, 09:38 | #1 (permalink) |
No Life Poster Join Date: Jan 2008
Member: 673661 Status: Offline Thanks Meter: 349 | E250I unlock ***sucssofly*** salut$ E250I not supported to unlock by ustpro nspro hwk and ather but heir its free for all This method is maybe known for some of you , i test it for some models (like E250 ,J600,J700 ..) and i think , it can work for all other models .. It's easy ,no risk at all , no cable , no drivers , but need to be handled well Today i test it on e250i , as we know ,many of us have a bad result after using box to unlock that fone , , (bad Imei ,bad BT adress ... ) but with this method ,, EVERYTHING is FiNe 1- Power on fone ,, type : *#7465625# you will identify wich code is active , wich is inactive 2- Remove battery ,, Put your sim card , not all of it ,, just to prepare it to be full inserted , put your battery back and power on fone ,, you must see " insert sim" not "invalid sim.." 3- type : *2767*3855# your fone should restart after 1 min ,, now ,, and before it restart , push your sim card ,,without removing battery 4- your fone should work and accept the sim card , , but if you chek locks you will find that your fone is still Loked 5- now type : *7465685*638*00000000*00000000# your UNLOCK CODE is 00000000 now , hh Enjoy 6- now , back to Locks table with : *#7465625# ,, and for each active code you can disable it ,,,here details : * Disables CP lock : #7465625*27*00000000# * Disables Network lock : #7465625*638*00000000# * Disables SIM lock : #7465625*746*00000000# * Disables SP lock : #7465625*77*00000000# * Disables Subset lock : #7465625*782*00000000# I wish It help , Regards live14Đ please poste resultat |
The Following 15 Users Say Thank You to live14 For This Useful Post: |
04-30-2009, 13:20 | #7 (permalink) |
No Life Poster Join Date: Jun 2003 Location: east london Age: 36
Member: 32195 Status: Offline Thanks Meter: 5 | trying this with a e250i. on step 5 5- now type : *7465685*638*00000000*00000000# after i type this nothing happens on the phone screen... i tried pressing the call button but it does not work.. then when i try step 6 to disable network code it says code error? any ideas? |
04-30-2009, 17:04 | #8 (permalink) | |
Freak Poster Join Date: Mar 2005 Age: 42
Member: 122774 Status: Offline Thanks Meter: 15 | Quote:
somebody knows what to do? | |
05-02-2009, 12:44 | #12 (permalink) | |
Member: 673661 Status: Offline Thanks Meter: 349 | Quote:
then type nck 00000000 | |
>>> Samsung E250i Unlocked <<< | zeel_zeel | Z3X-Team Products | 0 | 10-04-2009 07:37 |
>>>> Samsung E250i unlocked <<<< | zeel_zeel | NSPRO | 0 | 08-31-2009 19:18 |
Samsung E250i unlock code | flokay2002 | Samsung Flashers, Software, Firmware. | 0 | 08-11-2009 14:57 |
e250i unlock | shsarfraz | NSPRO | 4 | 05-05-2009 11:45 |
