Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Flashers, Software, Firmware.
Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms.
Old 10-09-2013, 11:51   #1 (permalink)
Member: 2042953
Question Samsung GT C6712 battery heat and dis-charging of mobile
pls help my Mobile Samsung Star-II duos model GT-C6712, the problem is that the mobile's battery is over heated and dis-charged due to unknown reason and then switched off and not working even after putting to charging.
pls give solutions if any one have and describe whether software or hardware problem persist in mobile.
Thanks in Advance
Old 10-09-2013, 12:01   #2 (permalink)
Member: 380023
Sonork: 1666713
Thanks Meter: 53
change your charging conecter
Old 10-09-2013, 12:15   #3 (permalink)
Member: 2042953
there is no issue on charging connector as i have two chargers even i have checked with other mobiles. due to that reason i have changed my battery even the same problem arisen and the battery is not useful now after inserting in to mobile s the battery was loosing its charging point and as mobile went on switch off mode the battery is of no use even putting on charging
Old 10-02-2014, 09:36   #4 (permalink)
Member: 1344108
battery connector
battery connector ways for samsung c6712 i need middle catt con ways
Page generated in 0.10476 seconds with 8 queries
