Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Flashers, Software, Firmware.
Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms.
Old 03-01-2003, 18:49   #1 (permalink)
Member: 13808
Thanks Meter: 163
Samsung read/write eeprom with flash cable HOW??
hi all,
Does anyone knows how to read / write eeprom into samsung phones using flash cable. I know its possible but i dont know how.
Thanx a million for your help.
Old 03-02-2003, 00:50   #2 (permalink)
Member: 17798
Sonork: 100.62007
Thanks Meter: 9
tool box 4.3
Old 03-02-2003, 05:38   #3 (permalink)
Crazy Poster
Member: 16329
How to use Tool box 4.3.1 to read and wite full eeprom?
In E2P manager only have R/W field piece by piece !
Which value for offset mode read?
Please get the link to download Toolboxhelp.
Best regards!
Old 03-02-2003, 08:15   #4 (permalink)
Member: 13808
Thanks Meter: 163
Where is the link to download toolbox help. anyone or any other software????????
Old 04-08-2003, 21:33   #5 (permalink)
Member: 17193
Thanks Meter: 16
@essojay
I also need it, did You find anything?
Old 04-08-2003, 22:02   #6 (permalink)
comunicatel's Avatar
Member: 10201
with samsung test program terminal via test mode.
This program is included in the Imei changer . But only for few models. And U should write a program that uses this protocol
Old 04-09-2003, 02:58   #7 (permalink)
msc-gsm's Avatar
Member: 25482
Hi essojay !
if you need toolbox 4.3.1 , please contact me by
ICQ:163939663
Best regards.
Old 04-09-2003, 04:21   #8 (permalink)
Member: 18218
Thanks Meter: 2
I HAVE TOOLBOX4.3.1 AND EEPROM FILES
DO NOT KNOW HOW TO REMOVE SYSTEM FAILURE CONTACT PROVIDER HELP!
Old 04-10-2003, 10:55   #9 (permalink)
Member: 17193
Thanks Meter: 16
Solution - thanx to nokiaunlocker -
Open toolbox
Go to 'e2p manager',
press 'program on'
select 'eeprom'
then 'e2ptstpattern' at the top
select 'write to eeprom'
type in the box : 0x2767
tick 'send command to phone'
and then press 'reset' om the left side TWICE
the phone should reboot and that should be it!
Not mine solution, again.......
But tested on 2 pcs, 100% working!!!!!!!
Old 04-10-2003, 11:35   #10 (permalink)
Member: 13761
Toolbox v4 and manual download link:
http://www.ringtonesaffiliates.com/p...on=file&id=164
Old 04-12-2003, 14:21   #11 (permalink)
mourad_t's Avatar
Member: 26438
Thanks Meter: 8
Unhappy
Hi
Can someone tell-us how to upload full good eeprom to SAMSUNG R210s, which software to use? and which cable (is it the same to flash?)?
Thanks
Old 04-12-2003, 23:08   #12 (permalink)
Member: 9224
Thanks Meter: 19
read old posts mourad
Old 04-12-2003, 23:19   #13 (permalink)
mobileland's Avatar
Member: 22955
Sonork: 67574 - Not use it
Thanks Meter: 584
Why doesn't anyone explain what and step by step should we do to write that ****ing eeprom in the phone.Does or doesn't anyone know for sure?
Old 04-13-2003, 18:55   #14 (permalink)
Member: 17193
Thanks Meter: 16
@mobileland
Everybody knows, but no1 wants to say...... Mail me
Old 04-13-2003, 20:53   #15 (permalink)
mobileland's Avatar
Member: 22955
Thanks Meter: 584
Thanks shoneb, I'll call you!
How I can read/write eeprom from 3210 without opening phone? youngcat Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 10-16-2003 19:14
Scheme for reading/writing eeprom from Samsung 100% working Bogi Samsung Flashers, Software, Firmware. 57 10-12-2003 18:50
How to read/write EEPROM of Sl45??? banKa x1x to x45/x50 0 02-20-2002 12:09
how to read/write eeprom/flash on Ericsson T20? sat Old Ericsson Phones & Sony Phones 6 02-08-2002 16:09
How to read/write Eeprom from C10e?? Probe x1x to x45/x50 0 05-30-1999 21:07
Page generated in 0.20933 seconds with 9 queries
