Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
02-20-2013, 21:55 | #1 (permalink) |
Insane Poster Join Date: May 2008 Location: Israel Age: 40
Member: 775828 Status: Offline Thanks Meter: 44 | What is i9300 internal memory file system??? I know that is internal SD is FAT32 or EXFAT-that for free space to use apps and media. But what file system using a firmware???? In I9000 this is REISRFS, But What in I9300 ???? IF any body know ,please write Here, its very important. thank you. |
02-20-2013, 22:01 | #2 (permalink) | |
Junior Member Join Date: Feb 2013
Member: 1887334 Status: Offline Sonork: 100.1627153 Thanks Meter: 6 | Quote:
02-20-2013, 22:21 | #3 (permalink) |
Member: 775828 Status: Offline Thanks Meter: 44 | In many of I9300 have corrupted internal sd, OK?! this is hardware problem-need to change NAND flash IC, and this is problematic. IN I9000 same problem, but i do trick with micro sd card (formating to reserfs and reflashing and etc.... and it is work perfect without change NAND. Same trick i want to do with I9300, but REISRFS format for this model dont work. |
02-20-2013, 22:30 | #4 (permalink) | |
i am not gives your actual solution but try above solution, hope it will be help | |
The Following User Says Thank You to Trade Mark For This Useful Post: |
03-07-2013, 20:03 | #5 (permalink) | |
Member: 775828 Status: Offline Thanks Meter: 44 | Quote:
But this solution to flash custom ROM on working Nandflash. In my situation i am looking and trying any solution with DED Nandflash without change it . See in Google " Sudden Death " and you will anderstand what i mean | |
09-20-2014, 09:36 | #6 (permalink) |
Junior Member Join Date: Jun 2014
Member: 2204252 Status: Offline Thanks Meter: 0 | hey genych even Iam looking for the same thing your looking out for my s3 has SDS and struck at splash screen and no product name in odin mode.... emmc had completely erased and iam not finding any of delar for emmc stock chips in market around me to replace it and i was waiting for the file system of i9300 so i can swipe emmc with sd card i'll be help full with u r updates and even i'll be updating you if i found that file system |
