Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
05-29-2017, 15:47 | #46 (permalink) |
Insane Poster Join Date: Feb 2008
Member: 709565 Status: Offline Thanks Meter: 6 | Nothing works, also i have phone rooted. Where do i get msl code. I install terminal su getprop ril.MSL And it just jump a row and nothing showing screen capture windows Really sorry if I got off topid but this is important as well for unlock Last edited by n1viperx; 05-29-2017 at 15:53. |
05-29-2017, 23:25 | #47 (permalink) |
No Life Poster Join Date: Sep 2007 Location: around
Member: 595864 Status: Offline Thanks Meter: 163 | hello tried your solution but no joy for me : 1. flashed COMBINATION_FA70_G955FXXU1AQDB 2. flashed with Z3X only system+sboot+boot+recovery+cache from G955FXXU1AQDG_OXM1AQDG_TUR 3. it gives some error and goes to recovery, i hit REBOOT, then asks for reset, and is only a RESET option in lower screen 4. restarts, and Google account is on pls clarify some aspects : a) wich version you flash after combination ? b) if flashing sboot and boot from regular firmware, it means no more adb ? c) before flashing COMBINATION, what version was on your S8+ ? thanks |
The Following 3 Users Say Thank You to nbkappa For This Useful Post: |
05-30-2017, 10:44 | #49 (permalink) | |
No Life Poster Join Date: Apr 2014 Location: Worldwide
Member: 2174901 Status: Offline Sonork: 100.1671257 Thanks Meter: 1,248 | Quote:
05-30-2017, 10:45 | #50 (permalink) | |
Flash combination then system+recovery+cache then flash sboot+boot | |
05-30-2017, 18:00 | #52 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Mexico
Member: 252707 Status: Offline Thanks Meter: 18 | i cant flash COMBINATION_FA70_G950FDXU1AQD1_Halabtech with z3x error in setup... device show: odin protocol version error. File analysis... Ok Total file size: 0x7CCA2DBC (1996 Mb) Searching USB Flash interface... COM5 detected Setup connection... error Done with Samsung Tool PRO v.28.1 i try with odin 3.12.5 error FAIL SHA256 is invalid |
05-30-2017, 21:26 | #53 (permalink) | |
Member: 595864 Status: Offline Thanks Meter: 163 | Quote:
hello followed your tutorial on youtube and after COMBINATION, did NORMAL (regular) firmware flashed in 2 steps : 1st. system+recovery+cache then reboot, and then some errors...skipped over and then 2nd. sboot and bin this is exactly as it was done in youtube. my result : bootloop. no matter wich COMBINATION and then Normal firmware, same bootloop. tried different files of COMBINATION and normal, but always bootloop. on youtube cant see EXACTLY wich firmware was used for combination, and after, wich firmware was used for normal flasing. so, if you would be kind and share full info... thanks | |
05-31-2017, 10:35 | #54 (permalink) | |
05-31-2017, 10:36 | #55 (permalink) | |
I use the same firmware I shared here try to flash 4 files and try again | |
The Following User Says Thank You to hosam kashto For This Useful Post: |
