Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
03-14-2017, 12:24 | #16 (permalink) |
Junior Member Join Date: Aug 2006
Member: 339239 Status: Offline Thanks Meter: 5 | Found some korean boards, mv7420 (mvtool(dot)co(dot)kr) and somee forum aesop(dot)or(dot)kr where there is described boot proccess, but can't download files. anyway sboot consist from: fwbl1 bl1 bl2 bl2 el3_mon el3 bootloader tzsw. We should probably use this name in cfg. Just to find sizes of every part of boot. el3 mon must be a second image, after that we can load sboot and everything else. |
03-14-2017, 12:37 | #17 (permalink) |
Junior Member Join Date: Jan 2005 Age: 53
Member: 106301 Status: Offline Thanks Meter: 10 | in engineering botloader v5.02, at offset 0x9c0e8 says "EL3 monitor information", maybe at this offset is for E7420.N.el3_mon.bin in "Galaxy S6 Boot recovery.pptx" there are 4 bin files : -7420.nbl1.bin -E7420.N.el3_mon.bin -bl2.bin -s-boot.bin |
The Following User Says Thank You to sataccount For This Useful Post: |
03-14-2017, 13:23 | #19 (permalink) |
Member: 106301 Status: Offline Thanks Meter: 10 | but in cfg file : DNW_STORE e5250 fwbl1 --> for BL1.BIN DNW_STORE e5250 bl2 --> for BL2.BIN DNW_STORE e5250 bootloader --> for S-BOOT.BIN DNW_STORE e5250 tzsw -->for TZSW.IMG and for EL3_MON¿? DNW_STORE e5250 ????? --> for EL3_MONITOR.BIN i've found another "possible" signature from offset 0x3dc10..0x3dd10 in sboot.bin (engineering bootloader 5.02) |
03-14-2017, 13:31 | #20 (permalink) |
Member: 339239 Status: Offline Thanks Meter: 5 | DNW_STORE e5250 el3_mon Thats how is written on Korean forum for writing with fastboot. All other names are same. They are using fastboot, probably just sboot is different, all other files are signed buy samsung and if you compile your own bl1, fwbl2 etc file must sent for signiture. I think that it should continue without releasing power key after WAIT if el3 mon is good. |
03-14-2017, 13:40 | #21 (permalink) |
Member: 106301 Status: Offline Thanks Meter: 10 | Finally phone accepts "DNW_STORE e5250 bootloader S-BOOT" with file extracted from G920F bootloader.. I've tested these four files and seems signature is ok, because downloader transfers ok, and does not gives any error : BL1 0..0x1FFF (size 0x2000) BL2 or EL3 0x2000..0x31FFF (size 0x30000) EL3 or BL2 0x32000..0x3dfff (size 0xC000) S-BOOT 0x3E000..10EFFF (size 0xD1000) in pptx, says that you must keep pressing power key during all process (transfer all four files). |
03-14-2017, 14:26 | #23 (permalink) |
Member: 339239 Status: Offline Thanks Meter: 5 | It doesn't load sboot in my phone, just hangs. I will try with another sboot. One more question, after DNW_WAIT, do you press power down and home to continue, or it just continue without touching? Did you reach odin mode at the end? |
03-14-2017, 15:09 | #25 (permalink) |
Member: 339239 Status: Offline Thanks Meter: 5 | At the end here is cfg file which worked for me: Code: ; S Project ; must keep order of binary list ; BL1 DNW_STORE e5250 fwbl1 200 20 novi1.bin ;DNW_WAIT ; BL2 DNW_STORE e5250 el3_mon 2000 20 novi_2.bin ; u-boot ; Wait Re-Enumeration DNW_WAIT DNW_STORE e5250 bl2 2000 20 novi_3.bin ;DNW_WAIT DNW_STORE e5250 bootloader 20000 20 novi4.bin ;DNW_WAIT ;DNW_STORE e5250 tzsw 20000 20 4pt.img Thanks once more time sataccount for your work. |
The Following User Says Thank You to zogu For This Useful Post: |
03-14-2017, 18:58 | #27 (permalink) |
Member: 339239 Status: Offline Thanks Meter: 5 | Used your offset from post 21. Novi1.bin 0..0x1FFF (size 0x2000) Novi_2.bin 0x2000..0x31FFF (size 0x30000) Novi_3.bin 0x32000..0x3dfff (size 0xC000) Novi4.bin 0x3E000..10EFFF (size 0xD1000) |
03-14-2017, 20:20 | #28 (permalink) |
Member: 106301 Status: Offline Thanks Meter: 10 | Zogu, Which version of multidownloader are you using? 32 or 64bits? can you pass the link for download it? i use sample_application v1.0 32bits (140.800 bytes) from 2013 Last edited by sataccount; 03-14-2017 at 20:26. |
03-14-2017, 20:28 | #29 (permalink) |
Member: 339239 Status: Offline Thanks Meter: 5 | 32 bit, found on some Persian forum and google translated it. I hope it is allowed to post a link: fars-gsm If it does not work for you, just try with more sboot.bin from different firmwares until you find some which works. I used same sboot.bin as firmware in phone. Last edited by zogu; 03-14-2017 at 20:34. |
03-14-2017, 21:23 | #30 (permalink) |
Member: 106301 Status: Offline Thanks Meter: 10 | the problem is that the downloader not accept "el3_mon" as label, can you check your file "WinDNWApi.dat" with an hex editor at "C:\Program Files\Samsung\Exynos USB Driver\Drivers" to check if you have a valid "el3_mon" entry and what is the address? maybe i have an old version of "disk1.zip" exynos driver and does not support "el3_mon" my WinDNWApi.dat size is 306 bytes |
