Mw 3026 Hardware Solution I FIND FIVE MINUTES AGO SOLUTION HARDWARE FAILURE MW 3026 %100 WORKŻNG |
Please write it!!! Hi! Can you say simething about this solution? I'm very interested in it!!! |
hw solution Hi! What is that solution??? |
please help me hi guys i have same problem. i'm waiting 2 mont please help us thank you for help ============================================== regards:confused: :confused: |
Plz if some one have the solution, he can pose it here, we have note the time tp lost, we are here to help and no to other things. Thanks |
@ardagul.... this forum is here for helping and providing info to others. if you have genuinely found a solution and want to share it then feel free to do so. But ... if you are here to do childlish pranks and waste space and other members time, you are in the WRONG PLACE. If you want o sell your solution then PUT IT IN SALES FORUM, WHERE IT BELONGS!!! |
Hello, I have same problem too. Why cant you send solution for all. Remember you MUST hane gotten most of your solutions from this Forum, why dont you give yours to others in return. Pls lets share. |
Perhapey you mean this solution: - I assume, that field 191 or 251 is 100% correct - Use SagemDR to change field 0 - Use SagemDR to read field 5374. Write it down and delete it. - Restart the phone -> SIM Missing - Enter the code for Monitormode (derived from the changed field 0!) - When you are in the phonemenue, take again Sagemdoc and repair field 0 to original value ( do not switch off the phone) - Take the value for field 251or 191 (It must be the correct one), convert it to decimal and enter it as unlock code. ->The Phone will reset the simlock counter... -Take again sagemdoc and restore the original field 5374 If you now restart the phone, it should be repaired (Simlock state like before, but perm. blocked gone) But this solution is old... Do you have another, faster more easy one? |
There are 2 solutions with use field 268. I think they several more simply! The first known long ago. Ardagul not once told about him in this forum. It is necessary know unlock code and use cable with connected +5V to pin1 . The second is more easy. It is necessary know phone ID. As is well known many models have a no restrictions on count wrong entering the code:) |
look post time 04-07-2002 23:58 I explain mine solution several times in this forum but this time mm3 code not knonw easyly way with mm3 code but some mw936 series it is usuable also this time regards all |
Re: Hardware Faulture.... Yes...solution from ardagul work fine...but not in each case! Some time, if E2P is damage and phone say : "Hardware Faulture, Pram error" (some fields are missing or have wrong length) ,with Sagem Doctor can't repair....and the only one solution is : Write correct E2P via Bootstrap mode.... |
@ Oxo Boxo. Yes you are right. In my case Sagem Doctor cannot see field 231 (I guess it is missing). Now how do I get the correct E2P for my phone(3026) and the method of writing it back to the phone? Thanks |
about....F231 @spectrum I think that you may corect F231 very easy via MM3 mode! To do same by Sagem Doctor and cable as latigido say, you must know phone ID! |
@Oxo Boxo The +5V on pin 1 method has been discussed many times before, but I do not quite understand the method. Can you pls tell me exactly what to do. And the second method, assuming that I know the ID, what next? Thks. |
Re: about....F231 Quote:
you need another way and wait 8 minute |
