Small update: - added hash tables 2C, 2F, 62 Small note: - if you use Hack3r2k Furisous calc - Manual calculator - hash tables 23 and 24 are bad |
Next small update: - added options for detecting hash table from crypted value (normal and special crypt) - hash tables 13 and 14: I don't know where I get and if tables are rights. Can someone test it? |
how to enter a code x-5 after geting code pls explain herer thnks for links |
i have already try but no success thnks friend |
Next update at http://encrypter.the.cz: Rebuild protected fields list 5250 - in this mode you can create new field 5250. Simply insert field 0, ID, select hash and as data insert field numbers separated with "," (example: 16128,16129,16140,16141,16178,185,227,268,5120,995 ) Multiple crypt/decrypt (normal and special) - if you want crypt/decrypt few fields in one step: as data use values separated with ",". Script crypt/decrypt all values at once. Warning: if you decrypt few values with this method - all must have same checksum length! Fields value compare - this is for lazy guys. Fill input DATA with two strings separated with ",". It's ideal for long fields as 16140. Script control length and compare these strings and return if are the same or on which position is first difference. |
@vozice_09 NEED LITTLE HELP.... I TRY IT WITH THIS LOG IT WAS CALC BY BB-GSM AT THIS FORUM.... Phone information: 436925007081 JB3,FI: 230904 1500 Field 0: 083A35330150895088 Field 5709: 906A45DD Hashtable 22 YOUR SITE GIVE ME THIS CODE.. Lock and unlock codes Code for level 01: 10268910-04 (new field 251: 3d351cfc) Code for level 05: 09569819-83 (new field 251: 390a62df) Code for level 41: 21134564-64 (new field 251: 7df8c950) Code for level 00: 10182867-13 (new field 251: 3cb1d279) Code for level 40: 20824872-78 (new field 251: 7c203bee) AND THIS CODE GIVED BY BB-GSM....... 20025660-47 YOUR CODE WORKS? I ALSO UPLOADING IMAGE THAT I ENTERD ALL DATA....PLZ CHECK WHER I AM WRONG? |
BUT SIR SORRY FOR THAT MISTEK....I AGAIN DO WITH RIGHT DATA.....ITS GIVING SAME CODES..... Code for level 01: 10268910-04 (new field 251: 3d351cfc) Code for level 05: 09569819-83 (new field 251: 390a62df) Code for level 41: 21134564-64 (new field 251: 7df8c950) Code for level 00: 10182867-13 (new field 251: 3cb1d279) Code for level 40: 20824872-78 (new field 251: 7c203bee) AND WORKING CODE IS THIS 20025660-47 WHERE I AM WRONG....I ENTER ONLY FIELD 0 AND ID FOR UNLOCK.......I HAVE TO ENTER FIELD 5709? IF YES THEN WHERE? |
If you have log like this: Phone information: 543102678975 JH3,BP: 230703 1755 Field 0: 083A15750860802813 Field 5709: Hashtable 22 THIS IS NOT ID - 543102678975!!! You must use any calc for detect your correct id! |
@hi sir tell me which code i use for unlock mw3020 @hi sir tell me which code i use for unlock mw3020 pleaseeeeeeee MODEL: MW 3020 IMEI: 350800350xxxxx-2 Lock and unlock codes Code for level 01: 11448854-68 (new field 251: 443d90dc) Code for level 05: 10898675-94 (new field 251: 40f60f4a) Code for level 41: 007105979-871059798- (new field 251: 043c4956) Code for level 00: 11664805-59 (new field 251: 458714af) Code for level 40: 009894573-598945735- (new field 251: 05e5cac7) log by astu Phone information: 031707245386 DI4,6J: 070802 1733 Field 0: 083A05083005385123 Field 5709: DEB7F542 Hashtable 21 Simlockdata for to: Code for monitormode: *226632623X2 X is a number from 0-9 phone id: FB9F31FF32D8 thanx a lot in advance cellworldd:( :( :( |
one cosmetic error at encrypter.. now repaired. Lock and unlock codes Code for level 01: 11448854-68 (new field 251: 443d90dc) Code for level 05: 10898675-94 (new field 251: 40f60f4a) Code for level 41: 00710597-98 (new field 251: 043c4956) Code for level 00: 11664805-59 (new field 251: 458714af) - unlock code Code for level 40: 00989457-35 (new field 251: 05e5cac7) - unlock code your firmware use in most cases lock level 01 - best way for unlock: start phone - use sagem doctor - edit eeprom field 251 - write and save value 458714af restart phone |
@vozice_09 hi freind thanx a lot but after unlock @vozice_09 hi freind thanx a lot but after unlock in phone no outgoing and no incomming call recive so tell me please what can i do pleaseeeee Quote:
celloworlddd;) ;) ;) |
Can you tell me where is located field 147 on a dump from MW959 read with Ponyprog ? |
