Infineon C16X M51 & ARM7 M52 BASED MYxxx: MY3078, MY3026, MY3027 MWxxx: MW3052, MW3042, MW3040, MW3020, MW936, MW939, MW939, MW930, MW940, MW3026, MW3027 MCxxx: MC3000, MC959, MC950, MC940, MC939,MC936, MC932, MC912, MC850, MC825, MC820, MC922 RCxxx: RC922, RC750, RC730 WAxxx: WA3050 |
10-23-2000, 16:58 | #1 (permalink) |
Junior Member Join Date: Oct 2000
Member: 2263 Status: Offline Thanks Meter: 0 | Sagem MC820 unlockable ????!!!! Until now, I haven't seen any 100% solution via datacable, eeprom, or PIC solution ! In the past, I have successfully unlocked an older Sagem MC820 (july 1999) by PIC solution, but on a newer one this does not work 100%. Is this phone unlockable ? Please help. |
10-26-2000, 11:22 | #3 (permalink) |
Member: 2263 Status: Offline Thanks Meter: 0 | Thanks Liquid, Are you sure about Sagem calculator works also on Sagem 8xx ? I thought it only works on Sagem 9xx. But I could not get the calculator work on a Sagem 912 and Sagem 920 (not by cable, and also not manually). I can make contact with Sagem Dr. v1.2 (4800 baud), but not with Sagem Calculator. Any idea why ? |
10-27-2000, 13:52 | #4 (permalink) |
Member: 2263 Status: Offline Thanks Meter: 0 | Sagem Calculator does not work for Sagem MC820, I tested it. No contact via cable. Manual, no unlock code generated. I get the following error: ------------------------------------------- Now you will have to type in these values exactly like you wrote them down! Enter value from E2P field 0: 083a23608902221804 Enter value from E2P field 251: 2a9d91bc Enter value at RAM address 0x219: 88be88884088 Field 0x0000: 083A23608902221804 Field 0x00FB: 2A9D91BC Phone ID: 88BE88884088 (is encrypted: 877887415178BEAE4078BEC0) c:\sagem\sgmslck.exe: incorrect data entered/retrieved or phone uses unknown SIM-lock mechanism. ------------------------------------------- Who has an another/better idea ? |
10-28-2000, 08:12 | #5 (permalink) |
Insane Poster Join Date: Nov 1999
Member: 663 Status: Offline Thanks Meter: 0 | Hi all I have two MC810 V with the same problem. All Sagem calculators(I meen free on the NET) for NCK don't work. I don't have solution on this moment for unlocking via cable. Will try old Pic solution but this not the good solution on problem. Any one have solution for 8xx??? Charlie |
Unlock Sagem MC820 and 840 | mobicell | Infineon C16X M51 & ARM7 M52 BASED | 1 | 03-28-2003 08:36 |
Sagem MC820 unlock | vz | Infineon C16X M51 & ARM7 M52 BASED | 2 | 06-20-2001 22:01 |
unlocking sagem mc820.. | timitiz | Infineon C16X M51 & ARM7 M52 BASED | 0 | 08-16-2000 21:51 |
Need dump eeprom for Sagem MC820 | Alexey | Infineon C16X M51 & ARM7 M52 BASED | 0 | 03-31-2000 21:05 |
Sagem MC820 unlock | Senior1 | Infineon C16X M51 & ARM7 M52 BASED | 1 | 06-12-1999 08:47 |
