ARM9 BASED M62 / M62+ All MYxxx Like: MY C3-2, MY X1-2, MY Z-55, MY X2-2, MY C-4, MY Z-3, MY C2-2,
MY V-75, MY X3-2, MY X-7, MY V-65, MY C-1, MY X-1w, MY C-6, MY C-5w, MY C-2, MY
X-2, MY X-6, MY G5, MY X-3, MY X-5, MW X1, MY V-56, VS2, VS1, MY C5-2, MY X-8,
MY X-4, MY C4-2, MY V-55, MY X5-2, MY C-3b, MY C-3s,MY100, MY200, MY300X, MY400, MY V-85, MY V-76,
MY X6-2 etc Also SG321i, VS3 & MY-S7 (Smart Phone) |
06-25-2004, 12:58 | #1 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Canary Islands Age: 53
Member: 17351 Status: Offline Thanks Meter: 41 | Sagem MyV-65 screen dead |
06-25-2004, 14:07 | #2 (permalink) | |
No Life Poster Join Date: Mar 2003 Location: england Age: 65
Member: 24552 Status: Offline Thanks Meter: 13 | Quote:
06-25-2004, 20:40 | #7 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,570 | ... Quote:
Br | |
06-25-2004, 23:15 | #9 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Canada Age: 44
Member: 24023 Status: Offline Sonork: 100.61317 Thanks Meter: 2,630 | i belive flash can't do nothing for this mobiles problem in V65 and X6 samthind bad solder pin result LCD don't work see my old post and you will understand |
06-26-2004, 00:25 | #10 (permalink) |
No Life Poster Join Date: Apr 2004 Age: 49
Member: 61294 Status: Offline Thanks Meter: 49 | wrong application on your LCD, would allows " bad connection". 2. adjust your phone flexi, before anything. 3.try your phone with another LCD. 4.if all application, are applied,before you can reflash, your phone. ****************bestman*********************** |
06-26-2004, 13:26 | #11 (permalink) |
Member: 17351 Status: Offline Thanks Meter: 41 | Its nothing to do with flash I took the screen out applied the 4 testpoints and then it said bad connection. I re-soldered but still the same. After about an hour messing about I decided that It would not unlock. So I put the screen back in pushed it right up and now it is either a white screen or one like an 8210 with a dodgy elaastomer. For some unexplainable reason the screen is now damaged. It is not the software for sure 100% @Hibititi i have looked through your old posts but cant find the one you are referring to!? |
06-26-2004, 16:05 | #12 (permalink) | |
06-27-2004, 08:17 | #13 (permalink) | |
Junior Member Join Date: May 2004 Age: 59
Member: 64278 Status: Offline Thanks Meter: 0 | Quote:
============== reply from alan [email protected] I done the same and found that after i refit the screen it come with white light or did not come on i fix it by pushing the ribbon connector down with out the screen ribbon in And then i slided it into the conector | |
sagem myv-65 white screen salution help | shani72 | Sagem Hardware Repair Area | 0 | 03-28-2009 05:35 |
i need code for sagem myV-65 | Platijet | Phone Unlocking Codes & Maps | 5 | 05-27-2004 16:32 |
Sagem MYV-65 code | lucian | Phone Unlocking Codes & Maps | 2 | 05-24-2004 19:58 |
sagem myv-65 firmware | darkieb | ARM9 BASED M62 / M62+ | 2 | 02-24-2004 17:51 |
Sagem MYV-65 | The Dog | ARM9 BASED M62 / M62+ | 3 | 12-17-2003 14:58 |
