myx-3 .no test mood help me hi myx-3 this set not go into the test mood.its imei no.3501049351767662 .i unlock this set but no response all new segam unlocker version 2.3 i has this soft ware but no response thanks :eek: |
help me to get out of this problem |
if you think "hotline menu", no this don't work with myx-3:( |
... Hi ! For unlocking u'r phone u don't need "TEST MODE". U need only field 0 and field 5709 that u can read with sagdoc and voila:D best regards, .:hack3r2k:. |
it does not go in the location of field what should i do now help me plsss 10x in advance |
You must to do it with cable und sagemdr_14c_plus |
Re: ... Quote:
i will tell u after checking it actually i have dongle 2.3 [email protected] 10x |
Your 2.3 might not do this. Use Sagem Tools by Gsmfunny - to change baudrate to 19.2k. You can then read fields 0 and 5709, and post in the log request section. Somebody will give you the code(s) You can also use the Sagem Code Reader (Original or Cloned) |
Not all versions supported by the calculator 1.7... |
thanks all of u for help |
