Upgrade MYX-3 to MYX-3d failed. Will get my baby runnin' again... Hi, I' m in desperate need of help: tried to play with thebuildin 'hotline menue' and changed some numbers in field 16140 as described on http://forum.gsmhosting.com/vbb/arch...c/83852-1.html Removed the akku and switched it on again - now the phone shows 'SIM locked'. Oh s*#t! Does I have a chance to get it it running again with a data cable (which I don't have yet, also no eeprom backup) and the appropriate tools? What are the steps to keep it running again if possible? Thank you in advance. -dgs -:( |
... Hi ! Smart move that a newbie to f*uck around with X3 phones :) OK..man pray to G O D and contact me ...:D If the test mode does not work on your phone then don't bother to contact me cause the other way to do that is secret and secret will remain so ... ICQ: #157715181 best regards, .:hack3r2k:.:D |
@dgs: have you restored previous field 16140 with datacable and sagem doctor? this is the solution. |
... @pitone02, do you mean, I should change all bytes I've flipped in field 16140 from 0xFF to 0x00 back to 0xFF with SagemDoctor? Then the phone will work again? Hope that the rest of 16140 which wasn't 0xFF didn't changed during reboot of phone through some firmware magic. I have no record of the old values. :-( But at first I have to wait for the data cable and use my old (but working) Mars Trium instead... Yesterday I was bursting with curiosity whats 'inside' the X3 (no backup, no data cable, no written down numbers...), now I left 'outside.' Hi Newbies, don't make the same way like me. Try to be on safe side before you change or modify something and don't rely on a working phone for some time. Thank you, -dgs |
in the posy started by me....the sequence of operation is simple. it is written "backup your old value before make change" you must restore your old value if you want your phone works. read it (field 16140) from another phone of same provider and try to write it to your phone....if you are lucky....phone works again |
