baterry discharge very fast and mobile is heated 1 Attachment(s) this can be happen to:A60,C60,C61,MC60 In some cases the following failure may happen to the mobiles which is described by customer as low stand by time and the mobile is heated to the keypad side. The reason is a short between the assembled board and SAR frame edges to two test pads. To solve the failure the test pads TP810 and TP840 of all C60 (A60, C61) mobiles and only the TP 810 for the MC60 mobiles shall be covered with sticker. |
ok thanks for this dear . |
Patrida do you know if the heat near the keyboard section of the SX1 is due to this problem or is it from the heat sink(copper leaf) placed underneath the battery? |
on SX1 heating is not usualy problem(like x60). maybe you must check for water damage etc. |
thanks man for the solution.It is really timely. |
tested by me and it's working very well !!! thank |
Work fine. thanks BR Amaro |
sorry for ask this m8s.... i have one MC-60 with no power condition.i check bord and its get 800+mA and power ic become heat. problem is this phone got "TW1603+B" number on it.but i cant find this number in market.is there any compatibe ic to this number??specially with mark dialog on it.there are common so easy to find... thanks. |
on any other old Siemens PCB |
Hi Platijet! I am in same situation with my cx65. Pls tell me what do I have to cover with stickers... Many thanks. |
