Siemens Hardware Repair Area all about Hardware Repairing you can get if here. |
03-02-2004, 11:39 | #1 (permalink) |
Crazy Poster Join Date: Feb 2003 Location: North Spain
Member: 22472 Status: Offline Thanks Meter: 1 | a50 turns off I have a new a50 (without guarantee), after turned on, insert pin, and in 1 minute the phone turns off. I´ve tryed with another batt, but the problem persist. Any idea? Best regards PaPiTo (Edit: without SIM, the phone don't turn off itself) Last edited by PaPiTo; 03-02-2004 at 11:53. |
03-02-2004, 23:08 | #4 (permalink) |
Member: 22472 Status: Offline Thanks Meter: 1 | Ok, thank for your responses. As i can see the problem is hardware. Then i can't make nothing, i'm not technician, and i have'nt element for make this repair. I think the problem ca be resolved by soft, but........ Thank you PaPito |
03-04-2004, 07:15 | #5 (permalink) |
Freak Poster Join Date: Feb 2003 Location: Tasmania Age: 55
Member: 21408 Status: Offline Thanks Meter: 0 | Hey, Chris02, with all my respect for you but this is not PA problem. What do you say if is a crystal fault ? 90% cases, if phone work only 1' is that the 13 Mhz not working and the clock the same to. Kindly regards, Dark |
03-05-2004, 14:48 | #6 (permalink) |
Insane Poster Join Date: Feb 2004 Location: India
Member: 54805 Status: Offline Thanks Meter: 2 | @Chris02 hi Chrsi02, ive posted you a query on A50 in another section already...(when i start the phone, it just goes orange display for a couple of seconds, there is a slight buzzz sound and it turns off).....could this be hardware problem...??? could anyone please lookup ? (in fact ive a similar problem with a new M55 that worked just a day... : ( tks n rgds... |
03-07-2004, 01:11 | #8 (permalink) | |
No Life Poster Join Date: Oct 2003 Location: Germany Age: 37
Member: 41076 Status: Offline Thanks Meter: 53 | Quote:
03-07-2004, 01:13 | #9 (permalink) | |
03-09-2004, 12:44 | #10 (permalink) |
Member: 54805 Status: Offline Thanks Meter: 2 | i am sorry being out of touch but was away..****s very much... the thread is: http://forum.gsmhosting.com/vbb/show...552#post656552 i really hope this helps... after doing this i am getting 'sos...insert your sim card' display sometimes. But when i insert a working sim the phone goes down again!!!!!!! |
03-09-2004, 12:51 | #11 (permalink) | |
Member: 54805 Status: Offline Thanks Meter: 2 | Quote:
will it help if i take a working A50 and put its firmware in the problem phone? in that case how do ensure taking a foolproof FUBU from working phone??? tks very much... | |
03-29-2004, 06:14 | #12 (permalink) |
Member: 21408 Status: Offline Thanks Meter: 0 | I have the same problem with many Sie A50. They switch off after a whilw, 4 hours, 6 hours. That it seems to happend only when they are used on network. In the lab never switch off. ( only if battery is empty ) Someone have any ideea ? Tnx, Dark |
SDIO WiFi turns off when XDA turns off | bankir | HTC & PDA WM( With Touchscreen) | 0 | 09-06-2006 08:46 |
SL45 turn off longtime. Should i turn off it by remove batt or without remove batt? | ^NaT^ | x1x to x45/x50 | 6 | 12-06-2005 03:19 |
a50 phone locked please turn off ! | ACE_UK | x1x to x45/x50 | 2 | 06-26-2004 11:50 |
8850 Turns on by self, turns off on keypad | jonnywhit | Nokia Hardware & Hardware Repair | 1 | 06-21-2002 01:41 |
A2618 Unable to turn on/ auto turn on and turn off | ED123 | Old Ericsson Phones & Sony Phones | 1 | 05-20-2002 01:03 |
