Siemens Hardware Repair Area all about Hardware Repairing you can get if here. |
07-12-2004, 15:16 | #1 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Russia Age: 42
Member: 17711 Status: Offline Thanks Meter: 1,858 | C60 becomes very hot after it is powered on... I have Siemens C60, which becomes very hot near keyboard after being switched on and discharged battery very quickly. But in powered off state it behaves itself ok. We tried to change Dialog IC and almost all belonging to network area - No result. Does anybody have any idea? |
07-13-2004, 13:21 | #2 (permalink) |
No Life Poster Join Date: Feb 2001 Location: Planet EARTH Age: 50
Member: 3194 Status: Offline Thanks Meter: 41 | hi friend, i have this problem too. Changed Dialog, and Cpu also not help. It must be some bad capacitor around cpu and dialog. But i have no part to replace it yet. If some one know the solution, please help us. |
07-13-2004, 16:50 | #3 (permalink) |
No Life Poster Join Date: Oct 2001 Location: No route to host. Age: 43
Member: 6772 Status: Offline Thanks Meter: 17 | Most simple solution: Disassembley the phone. Remove BB cover. Give power to phone and manually (touch all components) find out what is heating. Repleace faulty component. PS: Heat is not a monitor of the fault. If dialog is heating then other parts can also be faulty. Last edited by b0ba; 07-13-2004 at 16:57. Reason: grammer mistakes |
07-16-2004, 02:46 | #6 (permalink) |
Junior Member Join Date: Jul 2004 Age: 48
Member: 73060 Status: Offline Thanks Meter: 0 | It's drawing too much current which is not likely due to an IC or the processor. Are the LEDs very bright? Have they been modded at all? A o/c resistor or diode is more likely to cause over-voltage/current than anything else, even though capacitors can limit current. Plug in phone charger and probe the + and - battery connectors with multi-meter. Shouldn't be no more than 2V with no load (1.5v on my A55 ) I believe without battery in place. Also check the current using same method. If you're not sure how to do this with a metre, don't risk it. Current should be tiny, about 5-200mA at a guess, maybe even less (even though the charger is probably rated 300mA and battery at 700mA). If possible, test current and voltage with battery in place and phone on to get a more accurate real-time reading. This will tell you if the phone is operating out of range (I'm sure you'll be able to track down some specs for the phone). If you have flashed the phone, you might need to reflash the battery parameters to the original config. If you didn't save these before flashing, try searching the net as all original flasher files are available. Sorry I can't be of specific help, and I apologise for the vague values above. |
08-19-2004, 21:29 | #12 (permalink) | |
No Life Poster Join Date: Apr 2004 Age: 49
Member: 61294 Status: Offline Thanks Meter: 49 | Quote:
bestman. | |
W5 gets very hot after power on | y3kt | Motorola Hardware Repair | 0 | 12-25-2008 01:44 |
V3 Becomes Very Hot with battery Urgent!!!!!! | kaino147 | Motorola P2k | 3 | 03-16-2007 08:30 |
help 3310 in tornado it power on but with batterie it not power on | sofiame2006 | Nokia Hardware & Hardware Repair | 3 | 08-02-2005 08:46 |
t100 not power on after flash, not power on when original cable is plug | GYZMO | VLSI, Conexant, Skyworks and Old Models | 8 | 01-07-2004 00:34 |
How to fix sagem mw930 it not power on after flashing | zender | Infineon C16X M51 & ARM7 M52 BASED | 0 | 11-06-2002 08:02 |
