Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens Hardware Repair Area
Siemens Hardware Repair Area all about Hardware Repairing you can get if here.
Old 06-03-2005, 18:42   #46 (permalink)
Member: 142803
hi sevgsm et al.,
pls help me siemens A50 self charging solution.Treat as urgent.thanks
Old 06-08-2005, 16:31   #47 (permalink)
Member: 100195
Thanks Meter: 75
hi all
Originally Posted by donchichi
hi sevgsm et al.,
http://forum.gsmhosting.com/vbb/show...&postcount=719
The Following 2 Users Say Thank You to adilusta For This Useful Post:
Old 06-08-2005, 21:37   #48 (permalink)
pepik's Avatar
Member: 62102
Thanks Meter: 167
CX65 joystick ways
In *.rar archive is picture in better quality
The Following 4 Users Say Thank You to pepik For This Useful Post:
Old 07-12-2005, 12:59   #49 (permalink)
Registered User
ProfiTel's Avatar
Member: 59852
Thanks Meter: 7
@sevgigsm
have one cx70 swiching off random.
he can work fine for days and then turn off ...
tryed changing battery,full flash + eprom with martech, change crystal, reflowed cpu
still the same!!!
regards
Deki ProfiTel
Old 07-15-2005, 23:39   #50 (permalink)
sevgigsm's Avatar
Member: 81576
Thanks Meter: 2,128
Originally Posted by ProfiTel
@sevgigsm
still the same!!!
regards
Deki ProfiTel
dialog change
%1000000 tested ok.
The Following User Says Thank You to sevgigsm For This Useful Post:
Old 07-16-2005, 23:27   #51 (permalink)
sevgigsm's Avatar
Member: 81576
Thanks Meter: 2,128
C62 network problem
C62 network problem---------------
The Following 3 Users Say Thank You to sevgigsm For This Useful Post:
Old 07-18-2005, 18:46   #52 (permalink)
kardelen gsm's Avatar
Member: 133173
Thanks Meter: 119
hi
I have a cx65.. I put charger in the phone..charging is ok..but after a few seconds..not charging..I power on the phone.. in the screen..the battery was emptied..I try to flash the phone...same .. voltage is 3 V..any solution please help me..regards
Old 07-18-2005, 20:04   #53 (permalink)
Member: 129665
Thanks Meter: 4
Red face
siemens cfx65 not charging help me
lever 5 is not here
Old 07-18-2005, 20:14   #54 (permalink)
sevgigsm's Avatar
Member: 81576
Thanks Meter: 2,128
hi
lever 5 is not here
Old 07-18-2005, 20:47   #55 (permalink)
hitibiti's Avatar
Member: 24023
Sonork: 100.61317
Thanks Meter: 2,630
about C55 battrey is low !!!
i change resistor and i write battrey buckup i chnage PA , same problem !!
there is other solution ? !!
Old 07-18-2005, 21:25   #56 (permalink)
sevgigsm's Avatar
Member: 81576
Thanks Meter: 2,128
hi
1-dialog change
2-battery map software
3-cpu check
Old 07-19-2005, 08:35   #57 (permalink)
Member: 129665
Thanks Meter: 4
Talking
Originally Posted by sevgigsm
not charging
here %100 charging problem test ok
The Following 3 Users Say Thank You to mobilerepair1 For This Useful Post:
Old 07-19-2005, 09:14   #58 (permalink)
Member: 8792
sl55 missing line
I've sl55 missing line, how can i repair it (not change)
Old 07-19-2005, 09:48   #59 (permalink)
Member: 31047
Pls help for new siemens witch discharges batterie when you switch it on. And it displays BATTERY EMPTY, PLS RECHARGE. Thx. The model is A55 SIEMENS
Old 07-19-2005, 12:41   #60 (permalink)
sevgigsm's Avatar
Member: 81576
Thanks Meter: 2,128
c45 a50 same
Originally Posted by ekel
sevigsm can u help me please. i need picture of c45 charge way
http://www.lumeamobila.ro/placi.php
a50 charge problem
picture repair download
All Blackberry Hardware and Software Solution youssef01 BlackBerry (RIM) 34 11-01-2012 17:31
New All Special Hardware Tool simtech Nokia Hardware & Hardware Repair 29 03-08-2010 01:34
New All Special Hardware Tool gopalhot Nokia Hardware & Hardware Repair 16 07-24-2008 08:20
Page generated in 0.27454 seconds with 10 queries
