Siemens Hardware Repair Area all about Hardware Repairing you can get if here. |
11-13-2005, 13:39 | #124 (permalink) | |
No Life Poster Join Date: Oct 2003 Location: Germany Age: 37
Member: 41076 Status: Offline Thanks Meter: 53 | Quote:
11-16-2005, 14:07 | #125 (permalink) |
Junior Member Join Date: Oct 2005
Member: 191507 Status: Offline Thanks Meter: 0 | hi i have a problem with a sl55 , i changed the case and now the keypad doesn\t work , more exactly the OK pad, when the phone ask you if you want to turn on the phone, that keypad doesn\t work, thnx |
11-19-2005, 00:21 | #129 (permalink) |
Member: 195678 Status: Offline Thanks Meter: 0 | HI, I have problem with a70. It seems that element name v361 has burnt(after connecting pin1 to +12V) [i havn't got schamatic for a70 so it is element located in the same place as in a60]. Is there a chance to repair it ?? |
11-22-2005, 17:29 | #132 (permalink) |
No Life Poster Join Date: Dec 2001 Location: [☾✫ ] Age: 58
Member: 8159 Status: Offline Thanks Meter: 98 | have one cx65 phone charging ok but dont work on tryed changing battery,full flash + eprom with martech, change crystal, reflowed cpu stil the same |
11-23-2005, 20:18 | #133 (permalink) | |
Sounds like Keypad problem! Try EEPROM tools or anonther tool which needs manual ignition! | |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
New All Special Hardware Tool | simtech | Nokia Hardware & Hardware Repair | 29 | 03-08-2010 01:34 |
New All Special Hardware Tool | gopalhot | Nokia Hardware & Hardware Repair | 16 | 07-24-2008 08:20 |
