Siemens Hardware Repair Area all about Hardware Repairing you can get if here. |
05-15-2008, 08:24 | #1 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Online Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | benq-siemens a31 unlocking waiting for reply |
05-15-2008, 18:43 | #3 (permalink) | |
No Life Poster Join Date: Dec 2006
Member: 416908 Status: Offline Thanks Meter: 398 | Quote:
....hmmm, before post the question, first search bro.... https://forum.gsmhosting.com/vbb/f339/new-siemens-a31-unlock-free-joker-297259/ dagos | |
05-16-2008, 19:19 | #4 (permalink) |
Member: 322206 Status: Online Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | Hi Dagos I have a problem unlocking a31 using joker siemens egold version 0.3.5.6 inofficial , i have cut the testpoint as shown in pic posted in this forum , use model ax72/ax75 - c110/cf110 , com speed set to 57600 but the software always show me this error report error read flash block:0X800000 size:0X004000! the phone is working fine with locked sim . I atteched here the log of joker please guide me to unlock this phone |
05-17-2008, 07:15 | #6 (permalink) | |
set speed to 115200 bauds, not 57600 bauds. Joker working properly with this value. dagos | |
05-17-2008, 09:43 | #9 (permalink) | |
Member: 322206 Status: Online Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | Quote:
I forgot to tell you that I am using directcom for ufs software & using clone ufs as com interface please help me man | |
05-17-2008, 11:43 | #10 (permalink) | |
...hmmm, seems to be someting wrong in the bootcore area... Question: you correctly cut testpoint? If not working, remain to fullflash your phone and unlock it after.... dagos | |
The Following User Says Thank You to dagos For This Useful Post: |
05-17-2008, 17:59 | #11 (permalink) |
Member: 322206 Status: Online Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | it's working fine with it's own locked sim , so I think it's not a problem in bootcore area testpoint cutting is ok , I am affried to flash the phone using joker because I didn't done it before . can you please tell me the step by step flashing & unlock process using joker? please also send me the flash file can I use com cable? waiting for reply |
05-17-2008, 19:53 | #12 (permalink) | |
Error like "Error Read Flash block 0x800000 size 0x004000!" appair if speed is hight, flash chip not good supported by Joker or Com port not set corectly. Try to use other COM port (if your PC have two). Try to set from Control Panel -> System -> Hardware -> Device Manager -> Ports... and click on "Restore Defaults". Go to: http://forum.gsmhosting.com/vbb/show...ight=Guide+A31 and download it. You have inside the all informations and fullflash file. dagos Last edited by dagos; 05-17-2008 at 20:00. | |
05-17-2008, 21:58 | #13 (permalink) |
No Life Poster Join Date: Apr 2006 Location: On Earth
Member: 266339 Status: Offline Thanks Meter: 99 | sorry man for not noticing that you have tried the c110. So try the advices of Dagos(this man really masters siemens). If not working,contact me to give you fullflash. BR |
05-22-2008, 03:03 | #15 (permalink) |
Member: 266339 Status: Offline Thanks Meter: 99 | Your problem is 100% the emulated port you are using. Try to get a serial cable and attach it directly to comport. Reason: I have make correct tp of mc60 and A52.I use Directcom and ufs interface to unlock phones. Always get errors.Even to reflash the own FUBU into phones,i always get error.As i change and use a serial cable,all went successfully.No error more. See here the kind of error i get with directcom(part of the log) ****** Joker Siemens EGOLD Phone Version 0.3.5.2 Test Only opened. ****** ****** Donnerstag, Mai 22, 2008, at 03:08:03 ****** Start... Loading BootsModel(A51)... Sending StartBoot Ok. Sending MainBoot Ok. Error: SetSpeedBaud answer code 0xE2F36A! Start... Loading BootsModel(A51)... Sending StartBoot Ok. Sending MainBoot Ok. Warning: HASH data error! SIEMENS A52 lg1 Sw09 Soft FlashID: 002C/0016 FlashID: 002C/0016 Flash Size: 4Mb, WriteBuffer: 32 bytes Region(1): Blocks 32, Size 128Kb Start EEPROM segments at addres 0xBA0000 FSN: C40FD54E -> PhoneID: 4ED50FC4 OTP IMEI: 353616008767580 HASH: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF Use OTP IMEI: 353616008767580 USE SKEY: 12345678 *#0000*12345678# - Network Lock *#0001*12345678# - Service Provider Lock *#0002*12345678# - Corporate Code *#0003*12345678# - Phone Code *#0004*12345678# - Network Subset Lock *#0005*12345678# - Only Sim Read BCORE addr: 0x800000 size: 0x020000... BCORE Table Error! Read EEPROM addr: 0xBA0000 size: 0x060000... EEPROM backup in ".\Backup\A52lg1Sw09_EEPROM_080522031157.bin" file. Write EEPROM addr: 0xBA0000 size: 0x060000... ClearFlashSeg at 0xBA0000 does not answer! Open file "F:\FLASH FILES\Joker Own FF\A52lg1Sw09_80-40_FF.bin" for write in Flash. FullFlash file info: FlashID: 002C/0016 SIEMENS A52 Sw09 lg1 RealLgPack: lg1 Start... Cancel. Open file "F:\FLASH FILES\Joker Own FF\A52lg1Sw09_80-40_FF.bin" for write in Flash. FullFlash file info: FlashID: 002C/0016 SIEMENS A52 Sw09 lg1 RealLgPack: lg1 Start... Loading BootsModel(A51)... Sending StartBoot Ok. Sending MainBoot Ok. Com1 115200 BAUD: Ok. Warning: HASH data error! SIEMENS A52 lg1 Sw09 Soft FlashID: 002C/0016 FlashID: 002C/0016 Flash Size: 4Mb, WriteBuffer: 32 bytes Region(1): Blocks 32, Size 128Kb EEPROM segments not found! FSN: C40FD54E -> PhoneID: 4ED50FC4 OTP IMEI: 353616008767580 HASH: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF Error: EEP0067 not found! Error: EEP0076 not found! Error: EEP5005 not found! Error: EEP5007 not found! Error: EEP5008 not found! Error: EEP5009 not found! Error: EEP5012 not found! Error: EEP5077 not found! Error: EEP5093 not found! Error: EEP5121 not found! Error: EEP5122 not found! Error: EEP5123 not found! ClearFlashSeg at 0x820000 does not answer! Open file "F:\FLASH FILES\SIEMENS FLASH PACKS\BACKUP_ JOKER\A52lg1Sw09_BCORE_060116152752.bin" for write in Flash. Start... Loading BootsModel(A51)... Sending StartBoot Ok. Sending MainBoot Ok. Com1 115200 BAUD: Ok. Warning: HASH data error! SIEMENS A52 lg1 Sw09 Soft FlashID: 002C/0016 FlashID: 002C/0016 Flash Size: 4Mb, WriteBuffer: 32 bytes Region(1): Blocks 32, Size 128Kb EEPROM segments not found! FSN: C40FD54E -> PhoneID: 4ED50FC4 OTP IMEI: 353616008767580 HASH: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF ClearFlashSeg at 0x800000 does not answer! Open file "F:\FLASH FILES\SIEMENS FLASH PACKS\BACKUP_ JOKER\A52lg1Sw09_EEPROM_060116152839.bin" for write in Flash. Start... Loading BootsModel(A51)... Sending StartBoot Ok. Sending MainBoot Ok. Com1 115200 BAUD: Ok. Warning: HASH data error! SIEMENS A52 lg1 Sw09 Soft FlashID: 002C/0016 FlashID: 002C/0016 Flash Size: 4Mb, WriteBuffer: 32 bytes Region(1): Blocks 32, Size 128Kb EEPROM segments not found! FSN: C40FD54E -> PhoneID: 4ED50FC4 OTP IMEI: 353616008767580 HASH: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF Error: EEP0067 not found! Error: EEP0076 not found! Error: EEP5005 not found! Error: EEP5007 not found! Error: EEP5008 not found! Error: EEP5009 not found! Error: EEP5012 not found! Error: EEP5077 not found! Error: EEP5093 not found! Error: EEP5121 not found! Error: EEP5122 not found! Error: EEP5123 not found! ClearFlashSeg at 0xBA0000 does not answer! Open file "F:\FLASH FILES\SIEMENS FLASH PACKS\BACKUP_ JOKER\A52Vlg92Sw06_EEPROM_060222121626.bin" for write in Flash. Not valid file size! (size=393216). Open file "F:\FLASH FILES\SIEMENS FLASH PACKS\BACKUP_ JOKER\A52Vlg92Sw06_EEPROM_060222121626.bin" for write in Flash. Not valid file size! (size=393216). Open file "F:\FLASH FILES\Joker Own FF\A52lg1Sw09_80-40_FF.bin" for write in Flash. FullFlash file info: FlashID: 002C/0016 SIEMENS A52 Sw09 lg1 RealLgPack: lg1 Start... Loading BootsModel(A51)... Sending StartBoot Ok. Sending MainBoot Ok. Com1 115200 BAUD: Ok. Warning: HASH data error! SIEMENS A52 lg1 Sw09 Soft FlashID: 002C/0016 FlashID: 002C/0016 Flash Size: 4Mb, WriteBuffer: 32 bytes Region(1): Blocks 32, Size 128Kb EEPROM segments not found! FSN: C40FD54E -> PhoneID: 4ED50FC4 OTP IMEI: 353616008767580 HASH: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF Error: EEP0067 not found! Error: EEP0076 not found! Error: EEP5005 not found! Error: EEP5007 not found! Error: EEP5008 not found! Error: EEP5009 not found! Error: EEP5012 not found! Error: EEP5077 not found! Error: EEP5093 not found! Error: EEP5121 not found! Error: EEP5122 not found! Error: EEP5123 not found! ClearFlashSeg at 0x820000 does not answer! (with the last sentence,the procedure just brake up with directcom) With a serial cable:it accepts the same fubu and i write new Bootcore and unlock oading BootsModel(A51)... Sending StartBoot Ok. Sending MainBoot Ok. Com1 115200 BAUD: Ok. Warning: HASH data error! SIEMENS A52 lg1 Sw09 Soft FlashID: 002C/0016 FlashID: 002C/0016 Flash Size: 4Mb, WriteBuffer: 32 bytes Region(1): Blocks 32, Size 128Kb Start EEPROM segments at addres 0xBA0000 FSN: C40FD54E -> PhoneID: 4ED50FC4 OTP IMEI: 353616008767580 HASH: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF Data file "F:\FLASH FILES\SIEMENS FLASH PACKS\BACKUP_ JOKER\A52lg1Sw09_BCORE_060116152752.bin". Write Flash addr: 0x800000 size: 0x020000 - Ok. Start... Loading BootsModel(A51)... Sending StartBoot Ok. Sending MainBoot Ok. Com1 115200 BAUD: Ok. SIEMENS A52 lg1 Sw09 Soft FlashID: 002C/0016 FlashID: 002C/0016 Flash Size: 4Mb, WriteBuffer: 32 bytes Region(1): Blocks 32, Size 128Kb Start EEPROM segments at addres 0xBA0000 FSN: C40FD54E -> PhoneID: 4ED50FC4 OTP IMEI: 353616008767580 HASH: E49EFC89AEF6ED4F36D9BFDE2064CBBF Use OTP IMEI: 353616008767580 USE SKEY: 12345678 *#0000*12345678# - Network Lock *#0001*12345678# - Service Provider Lock *#0002*12345678# - Corporate Code *#0003*12345678# - Phone Code *#0004*12345678# - Network Subset Lock *#0005*12345678# - Only Sim Read BCORE addr: 0x800000 size: 0x020000... BCORE backup in ".\Backup\A52lg1Sw09_BCORE_080522034142.bin" file. Write BCORE at addr: 0x800000... Change BCORE HASH - Ok. Read EEPROM addr: 0xBA0000 size: 0x060000... EEPROM backup in ".\Backup\A52lg1Sw09_EEPROM_080522034228.bin" file. Write EEPROM addr: 0xBA0000 size: 0x060000... Change BOOTKEY - Ok. Change EEP0076 - Ok. Change EEP5009 - Ok. Change EEP5077 - Ok. Change EEP5121 - Ok. Change EEP5122 - Ok. Change EEP5123 - Ok. Change your cable and enjoy. |
...:::New Siemens A31 Unlock Free with Joker:::... | shahzaadbutt | E-Gold Based Phones | 76 | 07-30-2013 15:08 |
Benq-siemens A31 | pallumobile | Infinity-Box | 1 | 01-18-2009 10:49 |
benq semens a31 unlock | rajivmobil | Infinity-Box | 5 | 10-01-2007 12:58 |
BenQ Siemens A31 Schematic please...! | hendraz | Siemens Hardware Repair Area | 2 | 07-17-2007 16:25 |
" benq siemens e61 unlock?? " | afra.com | E-Gold Based Phones | 4 | 07-15-2006 12:01 |
