Siemens Hardware Repair Area all about Hardware Repairing you can get if here. |
06-13-2005, 14:06 | #1 (permalink) |
Freak Poster Join Date: Jul 2004 Location: Liverpool, UK Age: 40
Member: 75232 Status: Offline Thanks Meter: 12 | sl55 powres off when slide is closed any ideas? ian @ fonefix www.fonefixuk.co.uk |
06-13-2005, 15:07 | #2 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Little apt called Alhambra
Member: 13748 Status: Offline Thanks Meter: 84 | HI 65% soft problem, try to flash with a know good flash, or read from another. 35% display flex. Good luck Edit: I have remember a way to know. With phone registered to net and working, connect charger and wait 2h, or more, if you find phone turned off and no charger indicator then 100% soft problem. Best regards. |
06-16-2005, 16:35 | #5 (permalink) |
Insane Poster Join Date: Jan 2005 Age: 53
Member: 103401 Status: Offline Thanks Meter: 3 | I had the same problem twice. I thought it's flex cable or shock damaged phone or water inside or software problems - no - it was LCD board each time (the board where LCD is soldered). BR |
Z8 turn off when sliding | SLIPLOCK | Motorola Hardware Repair | 6 | 05-08-2009 18:52 |
n95 black screen only when slider is closed | themanisback | Nokia Hardware & Hardware Repair | 8 | 01-07-2009 14:17 |
A800 key pad light not off when phone is off | ijogo | Samsung Hardware Repair | 0 | 08-14-2006 10:44 |
SL65 power off when slide is closed ... | dghersin | Siemens Hardware Repair Area | 0 | 06-23-2005 21:47 |
V500 Wont Answer Calls When Flip Is Closed Why??? | mazdaspeed_FC | Motorola P2k | 10 | 03-07-2004 10:11 |
