USB DIV key not found error I am using Windows XP and Div 5.0. I made sure that I run userport.exe. When I double click on the Div 5.0 exe file, it says "Div Usb key not found". What could be the problem? Also, When I try to open Div 8.4, it says "Terminator not found". I dropped "NTPORTIO.sys" in c:\windows\system32\drivers directory. Please help. |
Try this, run userport, press start, then press stop, then run div usb. |
Make sure your Terminator dongle is plugged in securely and the power cable connected to your USB socket |
I made sure that my dongle is connected well and inserted the USB end into the socket. I also cleaned the connecting parts. |
Sounds like either your dongle is dead, or you have a TotalTools dongle instead. DId you buy this recently, or has this problem just occurred ? |
I didn't have any problem with this dongle before. No it is not TotalTools dongle. In fact, I used this dongle one day before I started having this problem. |
I also have problem with XP.. have terminator using ME with no problem.... now Im using XP and gives me "Privileged Instruction" then press: Do the JOb and nothing happens.... |
OK, here's another method then if UserPort does not work), run Div 8.4 first , then run DivLPT 5.0 (keep Div 8.4 running - don't close it). See if that works |
Didn't you made a bios reset before you start to have troubles with Div? Try to play with bios paralel settings. I had troubles with Totalmoto, and after a some settings in bios it worked OK. Total Moto olso uses paralel dongle with usb adaptor... |
I try opening 8.4 then div 5 and doesnt give me Privileged Instruction no more... but know it gives me error 0111 |
Finally...Fix it. I checked that all port setting and bios were ok. Put userport.exe, ntportio in same folder as div5 and userport.sys in Windows/system32/driver. Start userport and give at least 10sec (you can close it but dont press "stop") then open Div5 and everything ok..... If this doesnt work then you have a faulty dongle, and how to make sure, try it in another computer. Thanks to Bungle FYI I have Windows XP SP2. |
Glad you got it sorted :) WBR |
