08-24-2004, 19:12 | #1 (permalink) |
No Life Poster Join Date: Dec 2002 Age: 47
Member: 18855 Status: Offline Thanks Meter: 1,938 | Please Post Here All The Bug's in Griffin which you face up todate.. Please Post all Griffin Bug's Here which you face uptodate. This is the Bug's which i face till today... 1.Grifin have Bug's in Nhl-10 when selecting MCU it always come out .??? and we cannot find the MCU unless we must enter by manual or enter *.* to get the MCU 2.For flashing like 2300,1100 when select MCU ok but if select PPM we have to enter by manual.. 3.On NPL-1 if use griffin 2.05 it will flashing perfect include the .MLP if 2.085 always get error or fail. 4.Most latest models PPM info cannot appear while the griffin ini have the language info. |
08-25-2004, 05:50 | #6 (permalink) | |
No Life Poster Join Date: Dec 2001 Location: mumbai Age: 54
Member: 7889 Status: Offline Thanks Meter: 7 | Quote:
its possible i have fixed two ngage tiil now with adsp flashing might be not working with totaly dead adsp? | |
08-25-2004, 09:42 | #9 (permalink) | |
Member: 18855 Status: Offline Thanks Meter: 1,938 | Quote:
try formay user area. this thread is post about bug's... | |
08-25-2004, 13:05 | #12 (permalink) |
No Life Poster Join Date: Jun 2002 Location: Morocco, Rabat Age: 45
Member: 12504 Status: Offline Thanks Meter: 10 | we need latest good pinout for all model, because the most of problem is cable not 100% correct , can unlock and cant flash , initiation is too low ... |
08-25-2004, 14:22 | #14 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Brazil
Member: 18726 Status: Offline Thanks Meter: 26 | Griffin with Dct3 , problems : 3310, 3330,3410,5510,8210,2100 > error on full factory defaults,set faid and error detect IMEI, in 10 sequences of flash, 5 is errors in details up... in on > Griffin Gold and Griffin Platinum |
08-25-2004, 14:23 | #15 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Boston
Member: 21920 Status: Offline Thanks Meter: 10 | CP extractilon rarely works on 7250/6220/6230/most new models with camera... CP extraction on 7210/6610 sometimes fails and will NEVER work even after flashing MCU/PPM only then MCU/PPM/CP... User code reset does not work on most new models without factory reset NKCC is a great calc but what about ASIC6/7? |
Post here all the phonez unlocked with 3.9 cracked | makroud | Motorola P2k | 280 | 12-23-2010 22:21 |
Please Post here all the Pinout of this Models | DaWizard | Cyclonebox | 5 | 04-07-2010 07:58 |
please post here all the set that sucessfully spy defined and formated. | biochemistali | VE-PRO BOX | 7 | 04-20-2009 12:23 |
Please post here all the successful UNLOCK done by Jaf_Nokia_BB5_Unlocker 1.0 | kushstha | Nokia Base Band 5 ( BB-5 ) | 5 | 12-20-2008 17:08 |
Please post here All Antenna 1800 Band | NuengEve | Nokia Hardware & Hardware Repair | 0 | 04-03-2005 08:50 |
