07-17-2004, 00:00 | #1 (permalink) |
Junior Member Join Date: May 2004 Age: 44
Member: 65273 Status: Offline Thanks Meter: 0 | 3650 does not stay on |
07-17-2004, 00:54 | #2 (permalink) |
Registered User Join Date: May 2004 Location: Lebanon Age: 44
Member: 65294 Status: Offline Thanks Meter: 11 | hi there first u r using a combo flash which u have to flash only with mcu not mcu+ppm ...second now u have to flash ur phone with the ccerase file and then flash it normaly as i told u above then u may format user area and ur phone is ok regards... |
07-17-2004, 01:01 | #3 (permalink) |
Freak Poster Join Date: Jun 2003 Location: 9 JA
Member: 30405 Status: Offline Thanks Meter: 3 | Use 3650 erase bin to flash the ppm and the then reflash the mcu and ppm with normal flash after unlock and upload pm file for 3650 and evrything is ok. good luck!!!!! |
07-17-2004, 20:34 | #6 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | Full erase with 6600_Fullerase.bin after that flash with ver 2.50 or 3.16 not go Higher Otherwise It Difficult to make In ver 4.16 ,, commonly it comes on Blinking !!! |
07-18-2004, 07:36 | #8 (permalink) |
No Life Poster Join Date: Mar 2004 Location: pccomp Age: 42
Member: 59173 Status: Offline Sonork: 100.1585568 Thanks Meter: 225 | Just JOIN YAHOO www.yahoo.com |
07-21-2004, 00:13 | #11 (permalink) |
Member: 65273 Status: Offline Thanks Meter: 0 | I have tried to do the erase flash, but the phone never restarts after the flashing is done. My cable is already modified. Also, it wont restart after the full flash is done |
07-21-2004, 18:27 | #12 (permalink) | |
Crazy Poster Join Date: Jul 2004 Location: KSA
Member: 74223 Status: Offline Thanks Meter: 2 | Quote:
- click mcu and ppm choose pmmerase file (ppmerase.fia) - flash unit. - after flashing, unlock unit and write pm note: to write pm, press serial button (lower right) from features choose important PMM values press load file and write PM file (3650.pm) press write to phone button I have tried to do the erase flash, but the phone never restarts after the flashing is done.>>> Do full flash w/ mcu&ppm>NO SIGNAL>write 3650pm | |
07-21-2004, 18:43 | #13 (permalink) | |
- click mcu and ppm choose pmmerase file (ppmerase.fia) - flash unit. - after flashing, unlock unit and write pm note: to write pm, press serial button (lower right) from features choose important PMM values press load file and write PM file (3650.pm) press write to phone button >ps rename the attached file- ppmerase.fia.txt to ppmerase.fia 3650 pm.pm.txt to 3650 PM.pm | |
07-24-2004, 16:37 | #15 (permalink) |
Member: 65273 Status: Offline Thanks Meter: 0 | My problem is that when the erase file is flashed into the phone, the phone never autopowers, and Griffin says that the flash has failed. The cable I'm using is already modified |
Nokia 6300 does not turn on,only blue side lights on. | cpu2007 | Nokia Hardware & Hardware Repair | 13 | 09-02-2014 06:17 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
6131 Does not power on on battry but it works perfect while I connect UFS Cabel | .:.GSM-ANGEL.:. | Nokia Base Band 5 ( BB-5 ) | 1 | 10-25-2007 12:24 |
Trium Does Not Switch On But Lights Red Light When Put On Charger | tawanda | Mitsubishi | 6 | 01-16-2005 15:46 |
GX10 not Staying on | a5hek | Sharp | 8 | 07-05-2003 13:21 |
