6230i when tryin to use camera "Memory Full pls delete memory" whereas it empty insid @All I have a 6230i which is working fine, except for the camera, whenever i try to switch on the camera i get an error" Memory Full Pls delete some memory" but inside in gallery its all empty, i tried full erase, full flash, PM writing, fullfactory etcc....but still the same problem exists. is there any other solution thru whihc i can repair my phone? pls inform. WBR ReyTech. :confused: |
Try again is still not working your RAM is error must be change it (Hardware). Not software freez. :) |
Make " Format User Area " If Still not then Set Pictures Memory to MMC Card |
I have repaired one unit just by flashing MCU+PPM+CNT and camera working again.. WBR, |
[QUOTE=ReyTech]@All I have a 6230i which is working fine, except for the camera, whenever i try to switch on the camera i get an error" Memory Full Pls delete some memory" but inside in gallery its all empty, i tried full erase, full flash, PM writing, fullfactory etcc....but still the same problem exists. is there any other solution thru whihc i can repair my phone? pls inform. WBR ReyTech. :confused:[/QUOT Hi! solution hear! Make " Format drive" for all model upp tiku use: jaf,griffin.... tets 7600,6230,6230i..... |
i am also having some same cases but in a few i was able to repair by flashing i am also waiting for any persons reply that can solve this with software i am waiting can any body help me!!!!!!!!!!!!!!!!!!! thanks in advance |
