Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Griffin Products > Griffin
Old 06-12-2005, 05:52   #1 (permalink)
Member: 62016
Thanks Meter: 48
7650: Phone startup failed. Contact the retailer problem
have oe 7650 was okkkkkkkkkkkkkkkkkk just is sowing lock will buting new simcard asking for cord , just have unlock on griffin and set factry defult now is show phone startup failed. contact the retailer problem and the phone version 3.12 and have flash with 3.16 erased flasf and also flash with 3.16 version then also same have du setfactry defult.....................ok ans format userarea...................ok then also same have upload pm also.......................
any one have solutation
Old 06-12-2005, 07:30   #2 (permalink)
Member: 62016
Thanks Meter: 48
V3.4 BoxID:FF8A
SN: XXXXXXX
ACTIVATED BOX
using autopower
Initializing Phone...
Flash configuration:
9B04008900768800000200020100D122...
Boot and Flash loaders operation took 16.367001 seconds
Erasing - erase took 152.144007 seconds
Flashing PPM - flashing took 284.076013 seconds
Flashing DONE
After flash processing...
Phone data:
V 3.7.6.6/-26-09-02/NHL-2NA/(c) NMP.
IMEI 350774101099766
Product Code 0630600
Set Factory Default Settings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . set FAIL
No Java upload specified
AfpOK
Unlock DCT4
Local Mode confirmed
Sending Data ... SUCCESSFULL
Set Factory Default Settings set OK
Format User Area. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . FAIL
Format User Area. . . . . . . . . . . . . . . . . OK
FFSet LM . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . set FAIL
Old 06-12-2005, 08:51   #3 (permalink)
Rahuman28's Avatar
Member: 58172
Thanks Meter: 13
Do the procedure again with v5.06 and probably it will be alright. failure which check with the HW.
WBR
Old 06-12-2005, 12:28   #4 (permalink)
Member: 62016
Thanks Meter: 48
WBR
man you cahack the phone was ok and it was working fine it come for lock its dun after unlock from griffin
Old 06-12-2005, 12:46   #5 (permalink)
ChouChou's Avatar
Member: 53113
Thanks Meter: 16
try to format with Green, *, 3 and power on/off key pressed. i don't know for sure if it works with 7650 but with 6600, 7610 in most of the cases works OK.
hope it help you
Old 06-12-2005, 16:33   #6 (permalink)
tolski's Avatar
Member: 34750
Thanks Meter: 177
try to erase first,then fullflash with 5.06 and format user area.and post the result here.tnx
Old 06-13-2005, 05:01   #7 (permalink)
Member: 62016
Thanks Meter: 48
sir see this
Set UI Factory Defaults Ok, Time: 00:06
but format is ......... nothing ales on twister
but it 100% software
Old 06-13-2005, 05:28   #8 (permalink)
Member: 4600
Thanks Meter: 63
use format user area otherwise use combo flash method.
Old 06-13-2005, 07:42   #9 (permalink)
Member: 62016
Thanks Meter: 48
see this
V3.4 BoxID:FF8A
SN: XXXXXXX
ACTIVATED BOX
Trying autopower
Format User Area. . . OK
Phone data:
V prod_2003_wk15/-07-04-03/NHL-2NA/(c) NMP.
Product Profile file is: euroals.pp
Boot and Flash loaders operation took 9.793000 seconds
Erasing - erase took 12.965001 seconds
Flashing MCU - flashing took 0.001000 seconds
Erasing - erase took 12.776001 seconds
Flashing PPM - flashing took 0.000000 seconds
Flashing DONE
Trying autopower
Fail
using autopower
Boot and Flash loaders operation took 14.079001 seconds
Erasing - erase took 151.296007 seconds
Flashing MCU - flashing took 294.367014 seconds
Erasing - erase took 150.711007 seconds
Flashing PPM - flashing took 280.946013 seconds
Flashing DONE
Trying autopower
Phone data:
V prod_2003_wk04/-24-01-03/NHL-2NA/(c) NMP.
AfpOK
Write PM values
Sent
Write PM values
Sent
Old 09-25-2005, 15:11   #10 (permalink)
Stylo_GSM's Avatar
Member: 177235
Sonork: 111568
Thanks Meter: 133
Red face
Phone startup failed. Contact the retailer problem tahts wat i am geting wen i turn the phone on i jus chek i don hav v:5.06 on my jaf flash files please help me
on 7650
thanx:::::::::
7650: Phone startup failed. Contact the retailer. Greatgonzo Griffin 7 06-24-2004 11:39
Page generated in 0.31238 seconds with 8 queries
