Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Griffin Products > Griffin
Old 09-08-2004, 11:25   #1 (permalink)
saiful2001's Avatar
Member: 5509
Sonork: whatsapp : +351920243537
Thanks Meter: 200
what 's the problem on Griffin Server.
the server don't respond my request two weeks ago.
always
" Server IP: 2xx.xx.xx.xxx, Box_SN: 12345678
Connect... Resp: o/0110/hello there/8D2DE6E8A795E1F4B300BBFF9C7F580C
;Login...OK, available count 46;
busy, waiting...
e/400/command execution error;".
i can't make any profit from my investigation.
pls help.
Old 09-08-2004, 11:36   #2 (permalink)
Member: 21978
Sonork: sonork : 100.39764
Thanks Meter: 7
i suppose that you get this error with X70 logs.
Latest version is not supported by server yet.
Old 09-09-2004, 06:44   #3 (permalink)
saiful2001's Avatar
Member: 5509
Thanks Meter: 200
calc rpl for 2300 also this problem
X60 ,X70, RPL for 2300 also this problem.
Old 09-09-2004, 11:10   #4 (permalink)
s4sajii's Avatar
Member: 6919
Thanks Meter: 12
i get error msg ..
e/4 with x70 log.
any news for the prob solution.?
br
Old 09-09-2004, 15:02   #5 (permalink)
Member: 33690
Thanks Meter: 3,398
Hi
Hi,
I Also Had This Problem But I Managed To Solve It On Friday Last Week. I Unlocked A Panasonic X70 Successfully. For Griffin On-line Unlocking Use Only Win98se. It Did Not Work For Me On Winxp. Have A Nice Day.
Old 09-09-2004, 18:41   #6 (permalink)
Member: 64313
Thu Sep 09 18:39:18 2004
Server IP: 213.xx.xx.xxx, Box_SN: youwish
Login...OK, available count 7/0120/
NK FLASH IMEI 1
NK 7250 to 7250i 1
NK FLASH+UEM IMEI 2
NK 7250i+FLASH+UEM 2
Panasonic x70 2
Maxon 792x 1
Maxon 797x 2
NK ESN FLASH 1
LG-G7050 1
Panasonic GD55 1
Siemens ST 55 1
Panasonic G50 1
NK ESN FLASH+UEM 2
Panasonic x60 1
Siemens ST 60 1
Sharp GX30/TM100 2
LG C3100/C1200/C1100/7100/G7120 1
ive just tried with win XP and no problem
Old 09-09-2004, 21:21   #7 (permalink)
FU_Too's Avatar
Member: 55766
Thanks Meter: 333
02x1
NK FLASH IMEI 1
NK 7250 to 7250i 1
NK FLASH+UEM IMEI 2
Panasonic x70 2
Maxon 792x 1
Maxon 797x 2
NK ESN FLASH 1
LG-G7050 1
Panasonic GD55 1
Siemens ST 55 1
Panasonic G50 1
NK ESN FLASH+UEM 2
Panasonic x60 1
Siemens ST 60 1
Sharp GX30/TM100 2
that what I'm getting on Millenium edition but can someone tell me how i unlock an 02x1 with this? or do i need other software?
Old 09-10-2004, 18:45   #8 (permalink)
Member: 64313
02x1 is not listed ??
Old 09-11-2004, 01:00   #9 (permalink)
FU_Too's Avatar
Member: 55766
Thanks Meter: 333
Sorted
I found it, it comes under the maxon 792x. I thought like many others that it didnt work because when i put the code in (i tried 3 times) it still came up as sim not accepted. so i tried a read a second time and it produced the same codes. BUT before i had a chance to put them in again I had switched off fone for about 10 minutes. when i turned it on again it just accepted the orange sim i had left in it. so was unlocked. I wasted 2 logs by doing the second read but I'll know in future that it needs a bit of time to settle so to speak. I wish there were more concise instructions on how to use it though.
what is the problem with ur server.... R3İS Z3X-Team Products 6 01-23-2010 15:57
what 's the **** gsmalaa Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 1 09-18-2009 23:11
What is the problem with smti server,i loose credit without phone done segun4u SMTi 9 09-16-2008 15:11
Page generated in 0.20473 seconds with 9 queries
