06-23-2005, 21:29 | #2 (permalink) |
No Life Poster Join Date: Jan 2003 Location: Ukraine. Lviv Age: 43
Member: 19633 Status: Offline Thanks Meter: 13 | RROR CODES: [0000D301] Check location of FIA files. Otherwise download and install Griffin Gold Installer. [0000D303] Failure to auto power phone. Press flash and wait 2sec then press on/off on phone very quickly Set up everything then disconnect power to Griffin and reconnect after 5sec. Try above again. [5555FFBC] [22222222] FIA Files are old. Install newest flash package. Check folder structure regarding correct c:\program files\ or c:\program\ [21212211] FIA files are old or missing reinstall griffin or update FIA files [BDBDADAD] MCU and PPM versions are not the same, Verify that you have the latest FIA-files installed [78878778] Possibly no corresponding .fia file or flash chip is dead. In Griffin software versions lower than 1.983 occur while flashing 7650 and 3650 - need to be updated [78878778] Check the FIA files installation, upgrade to latest and verify that they are in the correct folder. Erase old ones then install new. Possible flash chip error. [FFFF9000] No communication with phone. [FFFF9100] Check the cable and connection to phone and check LPT settings in BIOS, EPP+ECP. [FFFF9200] Try bending the battery connectors a bit upward. In some connectors they have difficulties connecting. [FFFF9300] Possibly Flash IC malfunction. [44449000] [44449300] [FFFF8200] [FFFF917B] [FFFFFFC1] When flashing 9210. Maybe is your flash IC is corrupted or you need to reball the flash ic and try to reflash again. [FFFFFFD4] While flashing 3650 means that the box isn't updated to use with 3650. Upload last .gpd file to box. [FFFFFFBC] [FFFFFE36] Phone not detected correctly, upgrade Griffin to latest version. [FFFFB003] Possibly corrupted files in Griffin folder. Reinstall Griffin Gold Installer [5555B003] [33333333] Box is not activated If your supplier is unable to register your box, you must pay 150$ to The Griffin Team for registration. [BBAA1B34] [5555335D] Flashing 6600: Flashing 6310i: InvalidJavaUpload This is caused by mismatch in directory structure. Copy product info directory to c:\program files\nokia\phoenix\products\NPL-1 or to c:\program\nokia\phoenix\products\NPL-1. Flashing 7650: DE:3451 Check connection and power After flashing, do a manual factory reset by pressing *#7370#. It?s always wise to do a *#7370# before flashing symbian phones. Make sure the cable have a 3,3kohm resistor in serial from BSI to RJ-45. Start-up failed on Symbian phones Format user area. 3650, 7650 4x blink Make sure the cable have a 3,3kohm resistor between BSI and GND. "Invalid MCU flash file specified" Make sure the files are in the right directory. Make sure that the files are not read-only. Extracting content package fail Make sure PPM and CP file is from same version. Try flashing with MCU and PPM only then flash with MCU + PPM + CP If it still fails, try with other version. Make sure files are not read-only. Do a Full phone formatting on your 6600! as steps below, 1. Make sure you have at least 3/4 charge of battery power left. 2. Backup your contacts list and personal files to MMC memory card. Also backup sim-rebuild and pmm from phone. 3. Switch-off your 6600 phone. 4. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to switch on the 6600 phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 5. After a few minutes when the Full phone formatting completed, your 6600 will back to original system and factory setting. Normal reset *#7780# 3rd party apps remains Deep Reset *#7370# removes everything Gammu.dll was not found. Download gammu.dll from www.griffinteam.net and login with your box?s serial number. Place file in Griffin program directory. Is it possible to change IMEI with Griffin? With DCT-3 you can?t do it with Griffin, use nokiatool, knok, dejan, rolis or any other software for those phones. With DCT-4 you must first change UEM IC and then create a .ask file to send to someone who can make a .rpl from that and upload to phone. NOTE, changing IMEI is prohibited by law in many countries! Installation problems when installing latest Phoenix flash files. Install earlier versions of flash file and install latest again. Some of the flash files is updates from earlier versions. How to convert 7250 to 7250i Make ASK for 7250 repair/conversion, get RPL file, Flash with 7250i MCU/PPM/CP, upload ASK and PM values How to turn a flashed 6610 back to 6610 from 7210? Make a backup of your .pmm by using the serial menu and after flashing upload it to the phone again. If no backup exists, check the .pm file inside the nhl-4u directory and change ?. Then flash ppm again. Where to get the latest Griffin.exe file? Official releases of the Griffin.exe software is found at www.griffinteam.net and login with your box?s serial number. Where to get the Phoenix flash files from? Ask your reseller for password to their ftp-server or look around the forums mentioned above. Which cable goes to my phones? 5210, 8210, 8850, 8890, 2100 3310, 3330, 3410 5110, 6110, 6150, 6210, 6250, 7110, 6310, 6310i 6800 6800 6610, 7210, 7250, 7250i, 3200 3650 3650 5100 5100 3510, 3510i 9210 6650 6600 8910 6100, 3100 6510, 8310 N-Gage N-Gage 7650 7650 Enjoy Best regards Laval |
07-08-2005, 09:35 | #9 (permalink) |
Freak Poster Join Date: Apr 2004 Age: 44
Member: 61643 Status: Offline Thanks Meter: 14 | problem flash 6600 help me nokia 6600 flash error Initializing Phone... Flash configuration: 9B04002000BE8800000000022000BE88... Phone didn't confirm Algo upload Error[BBAA6600] |
07-20-2005, 09:00 | #10 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 71603 Status: Offline Thanks Meter: 31 | need help, i'm filash 6170, Griffin said: V3.4 BoxID:XXXX SN: XXXXXXXX ACTIVATED BOX using autopower Initializing Phone... Flash configuration: 9F0400EC00F822000011001000020000... Phone didn't confirm Algo upload Error[BBAA6600] I was reball CPU & UEM but it is still. Thanks. |
07-30-2005, 14:25 | #11 (permalink) |
No Life Poster Join Date: Aug 2004 Location: in my office Age: 48
Member: 78502 Status: Offline Sonork: 100.86270 Thanks Meter: 7 | ACTIVATED BOX Initializing Phone... Error[33333333] Initializing Phone... Error[33333333] Initializing Phone... Error[33333333] THIS CAME IF I FLASH 9210I IF I USED JAF OR UFS OR PBB OR PRODGY WORK GOOD SAME COMPUTER ONLY WITH GRIFFIN MY BOX ACTIVATED |
07-30-2005, 16:58 | #12 (permalink) | |
No Life Poster Join Date: Jul 2000 Location: hiroshima Age: 51
Member: 1756 Status: Offline Thanks Meter: 9 | Quote:
07-31-2005, 14:02 | #13 (permalink) |
Member: 78502 Status: Offline Sonork: 100.86270 Thanks Meter: 7 | hmmmmmmmmm i have more mcu orginal and colne but same i flash more mobile ok and work good only 9210i what u think ?Error[33333333] |
***Here Are Descriptions of NsPro Error Messages And Solutions For That Errors*** | NADEEM GONDAL | NSPRO | 10 | 01-12-2010 06:28 |
Griffin Team, explain this error message | afloat | MT-BOX | 1 | 10-11-2007 13:03 |
Griffin error message | quasim0438 | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 03-29-2006 07:06 |
instructions about error messages in griffin | kissdmiss | Griffin | 14 | 09-16-2004 09:56 |
griffin unk message 00 | gsmrazvan | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 07-20-2004 14:07 |
