11-08-2004, 15:54 | #2 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Next to the small lake, hunting crocodiles:-) Age: 51
Member: 50713 Status: Offline Thanks Meter: 0 | I had this problem with corrupt ADSP. Flash phone and after flash is finished, select ADSP file and under Special functions you will see Flash DSP Only, you must connect handset with mini-USB and install the drivers from phoenix folder. This should help. Jim |
11-08-2004, 16:51 | #3 (permalink) |
No Life Poster Join Date: Nov 2003 Location: Americas Age: 44
Member: 43802 Status: Offline Thanks Meter: 36 | I will try and follow what you say. I am a beginner with Griffin software for Flashing Nokia phones. I guess I can get the Flash File from Griffen Website I have no Mini USB cable ( Have motorola usb cable ..is it the same cable or is special cable for Nokia ) Not sure about Phoenix folder (where get software for this ?) |
11-08-2004, 18:03 | #4 (permalink) |
Member: 50713 Status: Offline Thanks Meter: 0 | mini-USB same as Motorola C350. If u used griffin installer you will have this folder: C:\Program Files\Nokia\Phoenix In here is another folder "FlashUSB". Here are the drivers for ADSP. When u try to flash ADSP for the first time you will get the "New Hardware detected" window. Point it to the FlashUSB folder and it will install ADSP drivers. After this you can flash ADSP part. Regards, Jim |
"PHONE OFF - phone won't get out of airline mode. | d1ulove | Samsung Hardware Repair | 0 | 02-25-2009 14:49 |
8310 - Cant get out of CAL Mode | v1ks | BlackBerry (RIM) | 0 | 01-28-2009 12:29 |
How to get out of Blank mode | involatile | GOT Motorola | 4 | 08-30-2007 20:19 |
How to get out of **** Diag mode without doing any sort of resetting? | Burnt Cobba | Sharp | 1 | 03-07-2007 22:47 |
How to get rid of consequences of input of a code *#73738# | lukasartsDon | NEC | 0 | 01-03-2005 18:31 |
