View Poll Results: About Griffin 2.0861 is: | |||
Worst then 2.085 | 22 | 26.83% | |
Worst ever | 7 | 8.54% | |
Better then 2.085 | 27 | 32.93% | |
Better ever | 26 | 31.71% | |
Voters: 82. You may not vote on this poll |
12-02-2004, 03:54 | #91 (permalink) | |
Freak Poster Join Date: Oct 2002 Age: 55
Member: 16430 Status: Offline Thanks Meter: 2 | Quote:
Cheers | |
12-03-2004, 02:53 | #92 (permalink) |
Freak Poster Join Date: Apr 2004 Location: Vanuatu, Port Vila Age: 43
Member: 63827 Status: Offline Thanks Meter: 1 | My problem solve... i need to update my box... but my pc give me error so i assume it was faulty, then i saw a post with same problem, he say he can't do update on his pc so he try other pc and it work. i rush to my friend shop n plug in my griffin n it was updated can be use again... but i dun think it can run on 2.85 anymore... it give me bad activation follow by the box id... but i am cool.. Thanks |
12-11-2004, 05:20 | #93 (permalink) |
No Life Poster Join Date: Sep 2002 Location: Portugal
Member: 15312 Status: Offline Sonork: 100.1576041 Thanks Meter: 1,097 | That is one of the first words on 2.0861 instruction manual. After update, won´t be able to run older versions like 2.085 and so on. |
12-17-2004, 09:34 | #94 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Canada Age: 44
Member: 24023 Status: Offline Sonork: 100.61317 Thanks Meter: 2,630 | i have problem with griffin , i try to flash dead Nokia 3220 i have this error : Initializing Phone... Flash configuration: 9B020100EC22F8000070110200000001... Boot and Flash loaders operation took 5.404000 seconds Erasing - erase took 83.450004 seconds Flashing MCU 01000000:0000002C, 00Flashing FAILED Make sure phone is connected and powered! ErrCodes: [13:0100] |
12-17-2004, 18:44 | #95 (permalink) |
Member: 15312 Status: Offline Sonork: 100.1576041 Thanks Meter: 1,097 | The common advice would be -> delete all FIA, reinstall lastest FIA and check cable... But you probably know and done that already... |
12-18-2004, 12:25 | #96 (permalink) | |
Member: 24023 Status: Offline Sonork: 100.61317 Thanks Meter: 2,630 | atell have help Quote:
i do it , i download fia flash files 3.51 from griffinteam and problem still same | |
12-19-2004, 17:13 | #98 (permalink) | |
Member: 24023 Status: Offline Sonork: 100.61317 Thanks Meter: 2,630 | Thx to Drug_Store Quote:
big thx for you freind , cose you help me a lot , but telme wher can i find flash_update_03_18_004-Oct28-151715.exe | |
12-19-2004, 17:22 | #99 (permalink) |
No Life Poster Join Date: Jul 2003 Location: LEBANON
Member: 33690 Status: Offline Thanks Meter: 3,398 | Try This HI, DOWNLOAD THE INSTALLER FROM HERE AND THE LATEST FIA IS IN THE INSTALLER. HAVE A NICE DAY. http://forum.gsmhosting.com/vbb/show...ffin+installer |
01-15-2005, 10:53 | #100 (permalink) |
Member: 24023 Status: Offline Sonork: 100.61317 Thanks Meter: 2,630 | hello i have problem her i have 3 mobile same problem ? 2* 6610i and 1 7210 Initializing Phone... Flash configuration: 9B020100800080000000800200000001... Failed to find FIA file in 'C:\Program Files\Nokia\Phoenix\flash\ In 9933534516f the cases this is caused by corrupt FLASH folder. Fully DELETE the contents of the Flash folder, and then Install the latest FIA package! Error[78878778] |
01-15-2005, 12:03 | #101 (permalink) | |
Insane Poster Join Date: May 2002 Location: Russia Age: 44
Member: 12338 Status: Offline Thanks Meter: 21 | Quote:
Rebolling flash ic and phone be worked perfectly, if flash good, but if the flash is bad change it. Another problem - is broken data between flash and cpu after water. Last edited by Tin; 01-15-2005 at 13:03. | |
01-15-2005, 13:38 | #102 (permalink) | |
Member: 15312 Status: Offline Sonork: 100.1576041 Thanks Meter: 1,097 | Quote:
Try doing as it says, delete FLASH folder adn reinstall FIA, maybe new 3.19.0 | |
