Federal One Federal One & Prodigy Support Section |
10-13-2006, 19:41 | #47 (permalink) |
Junior Member Join Date: Aug 2004 Age: 44
Member: 78762 Status: Offline Thanks Meter: 0 | Here some screen shot that i tried with some phone. N3250......Phone normal N73.........Phone goes NOKIA WHITE SCREEN something happened with APE CORE (I thing) because u can scan product. Problem solve when flashing with other box. And there's no product code. N3650 & N6600..........Phone normal but flashing between 15 & 19 mnt. DCT 4 & Old CDMA.........No Problem so far. Here the link...... http://www.forum-indoflasher.com/vbb...t=73195&page=2 Note: Need fix few bug, especially for WD. And product code with Variant Country, not only product code. Thank's BR Hendry Last edited by hendry_lucya; 10-13-2006 at 20:01. |
10-13-2006, 21:19 | #48 (permalink) |
Freak Poster Join Date: Nov 2001 Location: Asia
Member: 7650 Status: Offline Thanks Meter: 2 | Why cant someone answer a simple question of what cables to use for BB5 phones. There are no cables included with F1. It only comes with a USB A to B, a 10 pin to 8 pin converter, with no instructions on what cable to use. |
10-13-2006, 23:10 | #49 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: PHILIPPINES
Member: 101860 Status: Offline Sonork: 100.1582168 100.77603 Thanks Meter: 6,036 | Quote:
br RNC_EBM | |
10-17-2006, 04:57 | #51 (permalink) |
No Life Poster Join Date: Sep 2004 Location: NeverL@Nd
Member: 82106 Status: Offline Thanks Meter: 1,208 | Is this NSS support to create ASK file for DCT 4 and WD 2 Phones?!?? If yes, how we can do it?!? please explain me step by step to do that. If It Can Not do that, oohh... how poor this tool will be :-( |
10-17-2006, 10:24 | #52 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Nigeria
Member: 18200 Status: Offline Sonork: 100.1608286 Thanks Meter: 82 | This is unbelieveable. Some1 asks a fools question, and no one can answer him simply, only a lousy answer. OK again: WHAT CABLE DOES THIS BOX USE ? JAF 7 pin cables or UFS 5 pin cables ?????????????????? We know they are different on BB5 phones. But for DCT3,4, WD2, they are same |
10-17-2006, 12:59 | #53 (permalink) |
No Life Poster Join Date: Feb 2000 Location: UK
Member: 1024 Status: Offline Thanks Meter: 5,510 | Hi guys, Cables: You can use both type of cables, because F1 doesn't use the RX2 pin for flashing, neither the Vpp at the current moment(we will enable this only if sure that is 100 % safe). Just make sure you use the adaptor always. Slow flashing on DCT4: We were doing some testing on the F1 dll and set the speed to be 4 times slower then normal, just for the test, then forget to restore it. Sorry, will have new version very soon/or patch for the problem. DCT4 ask files: Those are created as a back up when you flash the phone, check the "/BackUp/Ask" directory. Its much better, since new phones don't have a backup RPL section in PM, so at least you sure you have backup of the phone identity. To create manually, select flash file(correct or similar) and use the Boot In Flash mode option (DCT4 Advanced Page). Hope this clears the things a bit. Regards |
10-18-2006, 21:20 | #54 (permalink) |
Freak Poster Join Date: Dec 2001 Location: israel Age: 69
Member: 7994 Status: Offline Thanks Meter: 20 | f1 Hi team i bay the new f1 but i canot work with the box i gut the cd with the SW NSS10374b.exe das it for this box? the updat NSS.EXE STABLE RELEASE 1.0.38.0 - 25 SEPT 2006 for the box is not good i dont see the SN for the box can u give me please working link ido |
10-19-2006, 09:36 | #55 (permalink) |
Member: 1024 Status: Offline Thanks Meter: 5,510 | Hi, Please download the latest version from our website. Uninstall the old version first, install the new one and follow the procedure for updating the driver carefully. I see in you screenshot that you're trying to install new version while you have already running NSS, please make sure that you run only one instance of the program, otherwise is not possible. Regards |
10-19-2006, 15:09 | #56 (permalink) | |
Member: 82106 Status: Offline Thanks Meter: 1,208 | Quote:
Been Tested in 3100 RH-19. The UEM Imei is ok, Phone in Local Mode but it's say Flashing Error when I klik "Boot". But after I flashed again the phone with NSS after that, then I klik "Boot" It's Done. think is as another Bug.... | |
10-19-2006, 16:35 | #57 (permalink) |
No Life Poster Join Date: Oct 2001 Location: ESTONIA Tallin Age: 49
Member: 6758 Status: Offline Thanks Meter: 294 | klik "Boot" work only if choose FAIL MCU. without MCU "Boot" work in Prodigy Plus Bph&co does not know as to make BOOT without MCU. I already wrote about this problem. |
10-20-2006, 10:29 | #58 (permalink) | |
Member: 1024 Status: Offline Thanks Meter: 5,510 | Quote:
I really dont have time for your emotional crap. Those are things i done in 2002, if you want something special contact me in private, pay and get or just stop post in our section. To the rest, if you find bugs, need help or improvments, please back up you postings with more info, debug logs etc. Any other type of provocations will be deleted as stated in the sticky posting by Daniel. Regards | |
>>> Federal One - Where to Buy <<< | RNC_EBM | Federal One | 28 | 12-01-2006 19:05 |
>>> Federal One - FEATURE REQUEST <<< | RNC_EBM | Federal One | 2 | 10-31-2006 10:43 |
>>> Federal One - FTP SUPPORT: FIRMWARE PROBLEM <<< | RNC_EBM | Federal One | 0 | 10-15-2006 11:21 |
>>> Federal One - Support Download <<< | RNC_EBM | Federal One | 3 | 10-15-2006 11:17 |
>>> Federal One - Account Login Problem <<< | RNC_EBM | Federal One | 4 | 10-11-2006 15:03 |
