Federal One Federal One & Prodigy Support Section |
03-07-2007, 18:06 | #1 (permalink) |
Banned Join Date: Apr 2005 Age: 42
Member: 137474 Status: Offline Sonork: 100.109924 Thanks Meter: 471 | N73 problem with write RPL !! !! NSS: RPL File: 359738001745597nss.rpl NSS: Checking RPL file...Done. NSS: Uploading SP locks...Write Error! NSS: Uploading NPC...Done. NSS: Rebuilding Security Area...Error! I use cabel with ressistor 5,1 and 7,5 on BSI line and 68k on BSI to GND and phone is on local mode and I change mode like I want and I can flash phone without problem with this cable.. And now I don't know what is wrong. After write this RPL I have contac service massage on phone and can't do anything more. I try full erase and after this write firmware and after this phone turn on but I have IMEI bad and simlock to all network and after write RPL IMEI is ok but I can't write simlock data. I need help. bye |
03-07-2007, 22:58 | #2 (permalink) |
No Life Poster Join Date: Feb 2000 Location: UK
Member: 1024 Status: Offline Thanks Meter: 5,510 | Hi, You can not rebuild the security area if the simlock is not uploaded. Try to make a fbus log please on upload. Is the IMEI bad after NPC upload ? This mean the log file is not correct. Regards |
03-08-2007, 10:11 | #4 (permalink) |
Member: 1024 Status: Offline Thanks Meter: 5,510 | Hi, Make sure you have internet connection while uploading the file and give NSS internet access from your firewall. You need have simlock upload success and then NSS will rebuild the security area using our server. Regards |
03-08-2007, 11:08 | #5 (permalink) |
Member: 137474 Status: Offline Sonork: 100.109924 Thanks Meter: 471 | I know this when I write simlock data rest will work but I don't know why I can't write simlock data always error is. ANy help welcome what to do to write this succesfull !! !! |
03-09-2007, 22:28 | #6 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Europe Age: 44
Member: 126827 Status: Offline Sonork: 100.70299 Thanks Meter: 60 | make sure phone is in local mode ,for this you need cable with correct resistance value - see help desk on F1 web site then upload only simlock by tick simlock check box in security and unchecked NPC |
03-10-2007, 02:59 | #7 (permalink) |
Member: 137474 Status: Offline Sonork: 100.109924 Thanks Meter: 471 | I have good cabel I know what I do becouse I fix 20 phones for now but with this phone I have always error when try upload RPL with only simlock data too. Always ERROR. Other help ?? |
Problem in write RPL on N85 with MT-BOX | Reza99 | MT-BOX | 7 | 09-03-2009 12:27 |
Problem in write RPL on N85 with MT-BOX | Reza99 | MT-BOX | 4 | 09-01-2009 14:08 |
problem with write RPL | hassan1975 | Cyclonebox | 18 | 05-05-2009 18:56 |
Problem with write rpl with N70 | kurdistan | Universalbox | 1 | 03-29-2008 21:44 |
Problem with writing RPL files | MM-GSM ServiceŽ | Griffin | 0 | 06-09-2005 02:11 |
