Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Federal One
Federal One Federal One & Prodigy Support Section
Old 07-07-2004, 02:30   #1 (permalink)
LogoMan's Avatar
Member: 17431
Thanks Meter: 22
Prodigy v 1.1010....Can't flash 7650
To; Prodigy Team
It stop flashing, when it start writing MCU experienced in 2 units already
BR,
LogoMan
Old 07-07-2004, 11:09   #2 (permalink)
Member: 47716
Thanks Meter: 14
Hi
Try To Flash With Skip Bt .hope It Will Work With You.
Old 07-07-2004, 15:51   #3 (permalink)
ricson's Avatar
Member: 18329
Thanks Meter: 144
same here also happened with 3650 flashing
Old 07-07-2004, 15:57   #4 (permalink)
Bph&co's Avatar
Member: 1024
Thanks Meter: 5,510
Originally Posted by LogoMan
To; Prodigy Team
BR,
LogoMan
Hi,
Can you check the version of the flash loader in your Flash dir ( from the .ini
file) please and let us know.
Old 07-16-2004, 13:23   #5 (permalink)
ricson's Avatar
Member: 18329
Thanks Meter: 144
i also experienced it mines a different error everytime flash erasing starts it says unable to erase block
experienced it 2 3650 and one 7650 but in other phones no problem in flashing
Old 07-16-2004, 15:59   #6 (permalink)
bluelights's Avatar
Member: 5324
Thanks Meter: 7
please make sure you have at least 3.09 FIA loaders installed correctly. and try again the flashing.
Old 07-17-2004, 03:55   #7 (permalink)
ricson's Avatar
Member: 18329
Thanks Meter: 144
i have 3.07 FIA where can i download 3.09 FIA files
Old 07-19-2004, 01:21   #8 (permalink)
LogoMan's Avatar
Member: 17431
Thanks Meter: 22
Originally Posted by Bph&co
Hi,
I've seen v3.09 but a week ago I install 3n1 istaller w/ my PC Griffin, Prodigy and Twister all in 1 .exe, does it effect flashing Symbian flashing? or I have to reinstall the v3.09?
BR,
LogoMan
Old 07-20-2004, 03:51   #9 (permalink)
ricson's Avatar
Member: 18329
Thanks Meter: 144
installed 3.09 FIA works fine now
Old 07-21-2004, 01:18   #10 (permalink)
LogoMan's Avatar
Member: 17431
Thanks Meter: 22
I'll try
BR,
LogoMan
Old 07-25-2004, 05:23   #11 (permalink)
cavite_devil's Avatar
Member: 47271
Thanks Meter: 25
try this method
downgrade fia files to 3.0.7 tested before i use fia 3.0.9 but cant flash wd2 pones in dct4 working 3.0.9 try to use 3.0.7 good for Dct4 and Wd2
Old 07-26-2004, 01:02   #12 (permalink)
LogoMan's Avatar
Member: 17431
Thanks Meter: 22
Thanks for the tip m8
BR,
LogoMan
Old 07-29-2004, 02:06   #13 (permalink)
LogoMan's Avatar
Member: 17431
Thanks Meter: 22
Hi,
P 4 1.7Mhz 256MBDDR 98 First Edition
can't flash WD2 phones, the rest of DCT4 are fine
use flash update v3.07 & v3.09
P III 600Mhz 256MBSDRAM 98 SE
all are ok, works perfect
BR,
LogoMan
Old 07-29-2004, 09:16   #14 (permalink)
Bph&co's Avatar
Member: 1024
Thanks Meter: 5,510
Logoman:
Please try to use the slightly updated dll i attach here, just extract and put
in your Prodigy folder replacing original Prodigy.dll.
Let me know about the result.
Old 07-30-2004, 01:14   #15 (permalink)
LogoMan's Avatar
Member: 17431
Thanks Meter: 22
Logoman:
How do I extract these files? w/ rar extension and text type file?
BR,
LogoMan
MT-Box 1.08 can't flash 2650???? suriyon MT-BOX 5 11-03-2005 13:22
New Prodigy version 1.1010 25th June 04 bluelights Federal One 93 09-01-2004 21:05
can't flash 7650 BT! Chris02 Twisterflasher 15 06-17-2004 20:36
I can't flash 7650 by prodigy pls help??? proxy_gsm Federal One 1 11-14-2003 14:31
I can't flash 7650 89007688 psych0 Federal One 0 10-06-2003 15:42
Page generated in 0.20807 seconds with 10 queries
