09-17-2005, 18:25 | #1 (permalink) |
Junior Member Join Date: Mar 2004 Location: ROMANIA Age: 42
Member: 56680 Status: Offline Thanks Meter: 0 | HELP Motorola HS 801 Headset + BT Dongle CANYON The problem is that my software don't recognize my headset at all. There is an options in BlueSolei for manually input the BT device address of my Motorola headset, but i don't know where to fint this address exactely. Maybe this software is incompatible with this type of headset ... that's why i'm trying to find some help here, maybe if i use another software (wincomm) it should work. I saw that wincomm is a little bit difficult for instalation and also i don't know where to download it and how to patch it. It's my first time when i'm using BT hardware and software Any help from you should be more than thanksfull. I hope to resolve my problem. Many - many THANKS ! |
09-28-2005, 21:42 | #2 (permalink) |
Crazy Poster Join Date: Jun 2002
Member: 13268 Status: Offline Thanks Meter: 0 | you need to put your headset to pairing mode (check manaual) the 801 is a little different from most other headsets. turn on the device by pressing one of the volume control and the MFB(big button on the center) then the blue lights blink once ever few seconds. now press and hold down one of the volume control for several seconds until the blue light stays on. thats when you click the center of the BlueSolei software the circle orange thing to seach for new devices. pair them (enter pin code eg. 0000) that should work. hope this helps. |
Jabra bt200 headset with USB BT dongle. | shermanx | Bluetooth-Software | 11 | 05-19-2006 01:36 |
Motorola HS 850 bluetooth headset | venomhotboy | Bluetooth-Hardware | 0 | 01-13-2006 00:47 |
HELP Motorola HS 801 Headset + BT Dongle CANYON | vladut_v | Bluetooth-Software | 2 | 09-19-2005 19:50 |
Cooked Motorola BT HS-801... | neles | Motorola Hardware Repair | 0 | 04-27-2005 11:19 |
FS Motorola HS-810 HS810 Bluetooth BT Headset (Pics Inside) | paid2surf | Sell ur Old and Used Stuff | 0 | 03-25-2005 08:19 |
