08-16-2004, 05:56 | #1 (permalink) |
Junior Member Join Date: Aug 2004 Age: 56
Member: 77871 Status: Offline Thanks Meter: 0 | Bluetooth Headset with XP SP2 It seem that XP SP2 dosenot support an audio gateway and it also stops my dongles software from installing properly to allow an audio gateway. Any suggestions would be greatly appreciated. |
08-26-2004, 20:42 | #2 (permalink) | |
Junior Member Join Date: Aug 2004 Age: 29
Member: 79371 Status: Offline Thanks Meter: 0 | Any solution found for your Problem? Quote:
08-27-2004, 06:36 | #4 (permalink) |
Member: 77871 Status: Offline Thanks Meter: 0 | I Found the solution After windows takes over and installs it driver do the following. 1 Go to Control Pannel 2 Double click on system 3 Select the Hardware Tab 4 Click Device Manager 5 Select your Bluetooth Device 6 Double click on your bluetooth Device 7 Select Driver Tab 8 Click Update Driver 9 Follow the prompts selecting your Bluetooth disc as the location of the files. Hope this works for you It did for me. |
iPod Shuffle BCK-10 Bluetooth Headset with Screen - White | IPMART | ipmart WebShop | 0 | 11-24-2008 12:00 |
iPod Shuffle BCK-09 Bluetooth Headset with Screen - Black | IPMART | ipmart WebShop | 0 | 11-24-2008 12:00 |
Compatible Nokia N95 Wireless Bluetooth Headset with Diamond - Black | IPMART | ipmart WebShop | 0 | 10-20-2008 13:00 |
Bluetooth Stack Error/XP SP2 | flydoc | Bluetooth-Software | 0 | 03-15-2005 09:22 |
UFSX can not run with XP-SP2 | mobilechen | UFS2 + UFS3-Tornadoflasher | 5 | 12-22-2004 17:19 |
