patch of the IVT bluesoleil 2.1.3.0 VoIP Release 060429 4 Attachment(s) patch was only tested with my bt devices. so i wish u can be fortunately enough to use this patch....if u r the unlucky guy,so, plz tell me. this is the link to download the original software : http://www.bluesoleil.com/download/d...luesoleil_voip and this is the release note and changelogs: http://www.bluesoleil.com/download/i...p_release_note The following significant changes have been made to BlueSoleil 2.1.3 VoIP since it is build 2.1.2 VoIP: Automatically show ever-connected devices on UI after BlueSoleil starts. //good news... Bug fix: DUN fails on windows 2000 OS. Bug fix: BlueSoleil does not support Nokia new phones (e.g. N series). Bug fix: For some Bluetooth devices, BlueSoleil still runs in evaluation mode after registering a license key. Bug fix: PAN cannot find physical network cards on some machines. Bug fix: "End program -IVT Corporation..." dialog is shown when the system is being shut down. Bug fix: BlueSoleil cannot run when there is no taskbar. Bug fix: When "Welcome to Bluetooth" is shown at the first run, BlueSoleil behaves abnormally after standby/resume the system. Bug fix: When PC suite 6.7 is installed and BlueSoleil is not set to auto-run on startup, more than one instance of BlueSoleil can run at the same time. Bug fix: On media center OS, if there are too many com ports, LAP does not work. |
I dont know how to thank you! I really want Bluesoleil VOIP version, I cant seem to buy from their site. I even offered to pay more for their service, they turned me down. This is really a life saver. Thanks |
Tanks, its works great!!! |
Thank you very much! I tried your other patch of bluesoleil 2.1.2.0 VoIP and it works also great! Maybe we can get more patches for future releases? Bluesoleil works great with my CSR-Dongle and Plantronics Pulsar 590a Headset. With WIDCOMM (even with 5.0.1.2500) I was not successful. Thanks again! |
2 lidouf Is it pissible to use your patch for NON VoIP version? |
this is not a patch. it's only a patched file? |
Patched Licensed File Actually Can i use By ISSC harlos with it .???...At now i am using Widcomm soft Reply Fast Any one? |
i'm poor in English..so the title of this post should be some confusion..I'm sorry for this...I restate as the following: ->this is only a cracked(patched) file(i wanna make a keygen at first, but its algorithm is some complex, so i give up this idea).. ->i didn't test on NON VoIP version..but I guess it can work fine.. ->it's ok for ISSC dongle, for mine is. |
thankx Lidouf So Cofirmation |
Thansk works like a charm and atleast it has good a2dp support *cought* widcomm *cough*. |
thanks work much much better than widcomm |
So yeah, before you accuse me of stealing, check your facts first. BTW, even with the patched version, I did send $15 cheque to Bluesoleil China. |
Thanks for the patch, for some reason tho, when I copy over the patched file and run the VOIP plugin, it says voip not suppored by this version...did I do something wrong? Thanks again |
I cannot install these patch. please they help me (Guidance) |
