Go Back   GSM-Forum > Non GSM/Mobile Related Forums > Bluetooth > Bluetooth-Software
Old 10-05-2009, 05:17   #1 (permalink)
Member: 177301
Thanks Meter: 47
Thumbs up Toshiba Bluetooth Stack Version 7.00.05
This new version was found by Seppok.
I think it would get more attention by having its own thread.
http://www.aziocorp.com/support/down...TD603-132.html
This is the version 7.00.05, x86 & x64 are in the same file.
I have tested and it works perfectly with my Dell Bluetooth module 350 & 360 (both are CSR chips), no crack required.
The Following 2 Users Say Thank You to Tseng For This Useful Post:
Old 10-05-2009, 22:03   #2 (permalink)
Member: 1133770
Thanks Meter: 3
thanks you very much!!!
Old 10-06-2009, 23:37   #3 (permalink)
Member: 295219
Last week I put the version 6.40.02 on windows 7 and it worked great for a couple of days and then for no reason the drivers disappeared.
So I just tried these and am getting the 'evaluation has expired' message and they don't work. Toshiba say it's the type of adapter used. The drivers are meant to work for one month only for developer testing on "non-supported" hardware or some crap.
So anyone know of a crack for this version please?
Old 10-16-2009, 11:01   #4 (permalink)
Gix
Crazy Poster
Member: 112022
Thanks Meter: 125
This is what you want...
The Following 7 Users Say Thank You to Gix For This Useful Post:
Old 10-31-2009, 05:54   #5 (permalink)
Member: 1150128
Hi, does it work on the latest version, 7.00.10?
Old 11-05-2009, 20:03   #6 (permalink)
Member: 1154630
Thank you , it is work!!
Old 11-08-2009, 00:50   #7 (permalink)
Member: 1156029
Thanks Meter: 4
Does it work with truemobile 355?
Tried it on one machine and it complains that usb is not connected. Modified the inf file then tried manually install driver with "have disk". Win 7 complained that it was not a correct driver for windows.
Should this driver be a straight forward install on truemobile 355?
Old 11-08-2009, 02:08   #8 (permalink)
Member: 177301
Thanks Meter: 47
Dell TrueMobile 355 is using Broadcom chipset.
You can use the WIDCOMM instead of Toshiba bluetooth stack.
Old 11-08-2009, 09:50   #9 (permalink)
Member: 1156029
Thanks Meter: 4
Tried
Broadcom Widcomm 6.2.1.0100
but A2dp headsets only has handsfree profile, need stereo
Old 03-05-2010, 23:35   #10 (permalink)
Member: 1252077
Thank you!
It worked perfectly and the "trial period" message disappeared. Thanks man
Old 04-21-2010, 05:58   #11 (permalink)
Member: 814116
Thanks Meter: 35
thank you this is what we want for V7!!
Old 05-08-2010, 15:51   #12 (permalink)
Member: 26130
Thanks Meter: 3
how do you exactly use this?
just double click on the exe and it will eliminate the trial?
thanks
Old 05-13-2010, 03:32   #13 (permalink)
Member: 1267962
It is what I want. Thanks Very much.
Old 05-20-2010, 07:28   #14 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 15,424
nice sharing thanks...
Old 06-12-2010, 19:19   #15 (permalink)
Member: 1314055
thanks nice sharing i needed this one
[IMG] code is Off
Toshiba Bluetooth Stack Version 7.10.04 is now available SLB Bluetooth-Software 19 11-04-2010 22:34
Now Available: Toshiba Bluetooth Stack Version 6.40.00 armond Bluetooth-Software 21 02-02-2010 16:35
Toshiba Bluetooth Stack Version 7.00.16 Tseng Bluetooth-Software 1 12-18-2009 04:18
Toshiba Bluetooth Stack Version 7.00.10 Tseng Bluetooth-Software 8 11-21-2009 03:45
upgrade my Toshiba Bluetooth Stack to Widcomm BT Stack jefbuan Bluetooth-Software 6 06-28-2007 16:29
Page generated in 0.29843 seconds with 11 queries
