Toshiba Bluetooth Stack Version 7.10.04 is now available hey all, on Toshiba's support site I found this version running well on Seven. CU Steve |
where is link????? please give a working link. |
I found it here Windows 2000 / Windows XP / Windows VISTA / Windows 7 x32/x64 7.10.04 x32 (x86 ;) ) & 7.10.04 x64 Haven't tried jet ... I'm using 6.2.1.500, later when finish downloading will update |
Edit: These stacks are for TOSHIBA notebooks only ! Simply wont work on other BT devices... If you got the spare time try it, maybe works for some other BT-s... On mine wont... |
is there a "cure" ? :) |
Does anybody have "remedy" for that version ? |
2 Attachment(s) Finnaly found a way to make a "cure" ;) |
Works fine. Many thanks to Gix ! :) |
Anyone get alot of noise inserted on the bt headset transmit end? I get that when I use it, then leave the computer on for 24 hours. |
x64 drivers Hi, do you know if the patches work for the x64 version?? |
Works great, thanks. Quote:
Adapter is Dell 360 BT module (Manufacturerd by CSR) |
