11-23-2005, 02:21 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 43
Member: 102577 Status: Offline Thanks Meter: 4 | Widcomm 5.0.1.802 A little new version of widcomm. I know, i know, it's the smalled point release of a widcomm version yet, but hey, it's higher then the last one :P Got it from the Logitech Setpoint 2.46c release CD. Get the 32 bit version here : http://www.megaupload.com/?d=BJ0NDHW6 and the 64 bit version here : http://www.megaupload.com/?d=PJM4IL7Y Phantasm, hope you can patch this one for us I'll upload the 32bit one as well. Adi Last edited by adisor19; 11-23-2005 at 02:34. |
11-23-2005, 21:18 | #2 (permalink) |
Junior Member Join Date: Aug 2005 Location: Russia Age: 49
Member: 173825 Status: Offline Thanks Meter: 0 | no problem, 32 bit version "servicepack" directory is ready now.... http://www.megaupload.com/ru/?d=HKH6KNHJ Testing please )) |
11-27-2005, 22:57 | #4 (permalink) |
Freak Poster Join Date: Oct 2003
Member: 40901 Status: Offline Thanks Meter: 2 | Try this for the x64 version - http://www.megaupload.com/?d=EBNPPEK0 Let me know how you get on. Also if you get the "Bluetooth license check failed. Please make sure that the bluetooth device you are using is licensed..." please post the exact message, there may be a number between the words CHECK and FAILED. I have placed these numbers into the various dll's so that I can see which dll is triggering this. |
11-28-2005, 00:11 | #5 (permalink) |
Junior Member Join Date: Oct 2005
Member: 190415 Status: Offline Thanks Meter: 0 | Hi, Phantasm. I got it working for like 5 minutes, maybe some minuts more when the tray icon turned red again and the message popped up "license failed bla bla.... No numbers between the words. Damnnnnn, I never had it working this long. I really thought it would stay working. |
11-28-2005, 00:31 | #6 (permalink) |
Member: 40901 Status: Offline Thanks Meter: 2 | Can you overwrite this DLL (btChooser.dll) into system32 http://www.megaupload.com/?d=TK9NYZ0J and see if it comes up with a number in the message then. Thanks. Phantasm |
11-28-2005, 09:17 | #7 (permalink) | |
Member: 190415 Status: Offline Thanks Meter: 0 | Quote:
11-28-2005, 10:01 | #8 (permalink) | |
No Life Poster Join Date: Feb 2003 Location: on the Moon ;) Age: 47
Member: 21937 Status: Offline Thanks Meter: 279 | Quote:
thx | |
11-28-2005, 15:06 | #9 (permalink) |
Member: 190415 Status: Offline Thanks Meter: 0 | Phantasm this is odd. I tried to do the same what you are doing. opening the dll's up in hex view and adding a number between words in that well known message, so you can know which dll gives the message. I've gone through all of them in the Data1.cab install package and I found only 3 files containing that message. btchooser.dll BtWizard.dll BTNeighborhood.dll after overwriting the installed ones with these, still the message appears without any number in between the words. |
11-28-2005, 18:30 | #10 (permalink) |
Member: 40901 Status: Offline Thanks Meter: 2 | its in bttray.exe as well (in 2 places), but yes I too am now getting that error and cannot figure out where its coming from. Also when it appears, if i end-task BTTray.exe it disappears, so its definately either coming from bttray.exe or a DLL that is loaded from bttray.exe oh and its also present in the 32bit version of the files, but ive never seen that error message pop up on any of the 32 bit releases. |
11-28-2005, 23:31 | #12 (permalink) | |
Member: 173825 Status: Offline Thanks Meter: 0 | Quote:
Hmmm... I use latest version of RAR, try to upgrade winrar to last version.. if problem not solved, i repack with zip | |
12-03-2005, 01:02 | #13 (permalink) |
Junior Member Join Date: Mar 2005 Age: 74
Member: 126419 Status: Offline Thanks Meter: 0 | Hi, does this drivers work now or not? I mean the problems because of the license... Maybe this files will help here too? http://forum.gsmhosting.com/vbb/show...3&postcount=23 |
12-03-2005, 01:23 | #14 (permalink) | |
Member: 102577 Status: Offline Thanks Meter: 4 | Quote:
Don't use the patch for the OLD version. Use the one mentioned above. Adi | |
Widcomm 5.0.1.802 with Crack | supertack | Bluetooth-Software | 0 | 05-20-2007 22:30 |
Widcomm 5.0.1.801 | luckyknight | Bluetooth-Software | 120 | 04-07-2007 13:12 |
Widcomm 5.0.1.802 + Vaio Integrated Bluetooth - Success! | ro76 | Bluetooth-Software | 6 | 02-11-2006 22:45 |
Confused with the 5.0.1.802 drivers... | icebreeze | Bluetooth-Software | 0 | 12-12-2005 22:05 |
SetPoint 2.22 + Widcomm 5.0.1.801 with CSR USB BT and dinovo keybd. | spd303 | Bluetooth-Software | 0 | 11-21-2005 21:12 |
