12-27-2003, 16:41 | #1 (permalink) |
No Life Poster Join Date: Jan 2003 Location: bestncheap Age: 43
Member: 19785 Status: Offline Thanks Meter: 1,242 | Matrik Support 6600,1100,3200,N-GAGE? How About Cables? matrik support 3200,1100,6600,N-Gage? how about the cables? same with griffin cables? or with prodigy cables? where i can buy the cables if matrik have support that phone? BR BNC |
12-27-2003, 21:58 | #2 (permalink) | |
Freak Poster Join Date: Dec 2002 Location: slovakia Age: 48
Member: 18876 Status: Offline Thanks Meter: 27 | Re: Matrik Support 6600,1100,3200,N-GAGE? How About Cables? Quote:
12-28-2003, 03:30 | #6 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Portugal- Center of Europe Age: 42
Member: 9502 Status: Offline Thanks Meter: 9 | yes cables are diferent from prodigy and griffin( both griffin and prodigy are the same)! and yes matrix flash 6600 and also n -gage 100% |
12-28-2003, 04:07 | #7 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Tutuban Age: 68
Member: 10635 Status: Offline Thanks Meter: 10 | griffin and prodigy cables not same... prodigy has 10 pins RJ45 while griffin uses 8 pins RJ45... BUT if you referring to clone prodigy, then the cables are same with griffin... BR, epic |
12-28-2003, 12:54 | #8 (permalink) |
Freak Poster Join Date: Oct 2003 Age: 55
Member: 40921 Status: Offline Thanks Meter: 0 | Cable 3200 is same as 7210. Cable 1100 is near the same as N-GAGE cable but use in emergency only. Cables 6600, 6650, 1100, and finaly N-GAGE is possible to order at your local DEALER - or directly from us at "[email protected]". By the way Matrix can flash and unlock 3100, 3200, 6600, 1100, N-GAGE. We still have not tested 6650 only, but I'm sure this will work too. If you use nowadays software to unlock 1100 or 3200 youu will receive ERROR -7 after unlock - this -7 is message from phone and it means that unlock ALGO 7 is well done. We will fix this in next upgrade. |
12-28-2003, 14:59 | #9 (permalink) |
Freak Poster Join Date: Mar 2003 Location: CT,SA
Member: 25213 Status: Offline Thanks Meter: 12 | N-Gage Have done mod's to box, do I need to put in 2k2 in n-gage cable to read phone, all that it does at the moment is saying " entering local mode-please wait...tried to enter test mode with no luck, also tried to put phone on in normal mode...lcd lights up then goes dead. |
12-28-2003, 15:57 | #10 (permalink) |
Member: 19785 Status: Offline Thanks Meter: 1,242 | @digitec cable was different? may i the pin out? may be i want modifify from prodigy cable or griffin cable.. cause i have many stock that cables.. can give link for pin out 6600 n N-gage n 1100? if i must order... its to expensive..n i think is better i modify its.. then i but just one pcs or 2 pcs.. BR BnC |
PM FILES 6610i 6230 7600 6200 1100 3200 | DeltaGSM | Nokia Multimedia | 8 | 04-28-2008 16:34 |
how about unlock 3200 via IMEI ? | pedroleroi | Phone Unlocking Codes & Maps | 10 | 01-20-2004 23:05 |
how about unlock 3200 via IMEI ? | pedroleroi | Phone Unlocking Codes & Maps | 2 | 01-19-2004 20:40 |
Nokia 1100, 3200 Direct Unlock and Flash | ufs2flasher | UFS2 + UFS3-Tornadoflasher | 10 | 01-07-2004 16:31 |
