Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > UFS2 + UFS3-Tornadoflasher
Old 05-25-2006, 13:47   #1 (permalink)
Registered User
imran_k's Avatar
Member: 66075
Thanks Meter: 2
1600 which cable to use? to flash
hi all
please help
which cable do i use for 1600 on ufs3
thanx in advance
wbr
WBr
Neo
Old 05-25-2006, 14:20   #2 (permalink)
Dirdan's Avatar
Member: 192348
Thanks Meter: 6
You can use 1100 cable.
Best Regards
Old 05-25-2006, 14:41   #3 (permalink)
Registered User
imran_k's Avatar
Member: 66075
Thanks Meter: 2
i tried 1100 cable but it does do nothing , all it does is just make a funny noise
i also tried 2600 cable and this is the log i got :
1st Boot Ok, DCT4, UPP: 2201
Fl0: 0x01000000-0x013FFFFF,00012A7E,Amd 29BDS320
Algorithm: u_amd.fia, Ver: 4.19.0
Algorithm Ok, MSID: 84001AF3ABEC0A0CB458E7078B
Decoded MSID: 3E4EBAE9-00028509-A8000000
Encoded FAID: BB10A707-91A16F9E-E08FC9C1
Erasing: 0x01000000-0x0100FFFF ...
Erasing Error: 10, at: 0x01000000-0x0100FFFF, 940207, Time: 00:00
Process Failed, Repowering Mobile
please help urgently , its not able to flash with 2600 cable
thanks in advance
wbr
Neo
Old 05-25-2006, 14:51   #4 (permalink)
The SAINT®'s Avatar
Member: 111249
Thanks Meter: 531
U have to use the 1100 cable for sure, check if the cable u r using is ok. On the other hand the cable for 2600 is also same...
PS: If u have the easy flash cable, that will b the best solution.
Old 05-25-2006, 14:51   #5 (permalink)
..::Mr999::..'s Avatar
Member: 154749
Sonork: 100.92483
Thanks Meter: 1,048
1100 cable work fine for me...i did unlock many phones (1600) with that cable..
try to hold tight
Old 05-25-2006, 14:55   #6 (permalink)
Registered User
imran_k's Avatar
Member: 66075
Thanks Meter: 2
unlock is working fine with 2600 cable , but i need to flash the phone to different version
please help
thanks in advance
wbr
Neo
Old 05-27-2006, 16:54   #7 (permalink)
The SAINT®'s Avatar
Member: 111249
Thanks Meter: 531
u can do it with the same cable mate. Just select the required files connect the phone n flash it.
Old 05-27-2006, 17:48   #8 (permalink)
GamalyGsM's Avatar
Member: 154404
Thanks Meter: 131
1100 / 2600 / 1600 / 1110 the same cable ...
make sure ur cable is working fine ....
and change ur v for ufs
and change ur fia files
Algorithm: u_amd.fia, Ver: 4.19.0 too old
ragrads
==Gamaly@GsM==
Old 05-28-2006, 19:16   #9 (permalink)
Member: 39245
Thanks Meter: 43
Check cable... make sure cable is ok...
If cable is ok that's would be hardware problem.
Change Flash IC (glued)
Old 05-28-2006, 21:11   #10 (permalink)
mg70brz's Avatar
Member: 18726
Thanks Meter: 26
or use the new easy flash cable,included on new equipaments since february/2006,ex: ( n-box/twister/powerflasher/tornado) i am tested and flash nokia > 1110/1600/6060 OK !!! very easy,connect on phone and read info ,select flash and no bad contacts to cause a noise on flashing process,its best !!!
ps: have schematics of this on this forum !
Old 05-29-2006, 14:58   #11 (permalink)
Member: 273997
Thanks Meter: 8
please help
thanks in advance
wbr
Neo
1100 and 1600 2600 2300 1110 cables are same
Old 11-29-2006, 23:23   #12 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
i have a easy flash cable and i can flashed the 1110 set with UFS but it is not flashing the CNT file and doesent do any UI setting ..
y is that so ?
for that what we have to do ?
Old 12-02-2006, 08:33   #13 (permalink)
~mr_Ten$ion~'s Avatar
Member: 135601
Sonork: 100.1612518
Thanks Meter: 68
Flash it wid JAF .... This Saras Boxes Hve Prob dis Error 10
But JAF is Best in tht .... SO try to flash it Wid Jaf ....its may help u ... thanx
thanks in advance
wbr
Neo
Old 12-02-2006, 08:56   #14 (permalink)
Member: 241105
I have tried downgrading software version to 3.08 with 1100 cable but got an error and kiled the phone. After this tried using 1100 and 2600 cable and reflash either with version 3.08 or version 3.42 but now getting another error.
1st Boot Err: Bad Resp DCT3, C3 D3 5
Cannot Detect Mobile Brand
Fl0: 0x01000000-0x01FFFFFF,00EC2268,Sam No Name
Algorithm: u_amd.fia, Ver: 4.49.0
Algorithm Ok, MSID: 848B209DB1F898ED3E9B6EDB6D
Decoded MSID: 3E4EBAE9-001164A6-A9000000
Encoded FAID: B5C814FA-6A948F89-47A564D9
Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00
Area2: 0x01010000-0x013BFFFF Erased, Time: 00:25
Area3: 0x013C0000-0x013EFFFF Erased, Time: 00:01
Erasing: 0x017C0000-0x017EFFFF ...
Erasing Error: 10, at: 0x017C0000-0x017DFFFF, 940207, Time: 00:00
What is the best MCU, PPM, CNT files to use? What version and exact file name?
What do you suggest to do to fix this?
Thanks HEAPS
Old 12-02-2006, 10:23   #15 (permalink)
Member: 135601
Sonork: 100.1612518
Thanks Meter: 68
Bro flash wid JAF ... & version is 5.53 .... Working 10000%% tested
post results
Thanks HEAPS
which cable i use to unlock CU400 and U900? bumzuco VygisToolbox 1 11-10-2007 02:39
which cable tu use to unlock x660 samsung with HWK djouaka HWK 8 10-05-2007 08:27
Sony Ericson J100 Which Cable Is Used To Unlock It? touch_111387 Sony Ericsson 7 02-27-2007 05:16
which cable you use to unlock E315 316 317? cauchemar Trident/AGERE Platform 15 05-27-2005 23:52
Page generated in 0.26108 seconds with 10 queries
