07-03-2006, 10:37 | #1 (permalink) |
Registered User Join Date: May 2004 Location: south africa Age: 41
Member: 66075 Status: Offline Thanks Meter: 2 | 1100 not flashing ? help i have 1100 that i need to flash to change the language but its not booting with hwk , but the phone is still coming on here is a screen shot |
07-03-2006, 11:18 | #4 (permalink) | |
Freak Poster Join Date: Apr 2000 Location: hongkong Age: 55
Member: 1269 Status: Offline Thanks Meter: 485 | 1100 cannot communicate with ufshwk Quote:
first u must check if cable is ok i mean some pins in cable connection is ok or is bend secound also phone can be bad i mean internatl connection of the phone also we all are using this boxes require some tecnincal skill and some experience i hope u can understand narry | |
07-03-2006, 11:30 | #5 (permalink) |
Member: 66075 Status: Offline Thanks Meter: 2 | @Narry cable connection is fine , no pins are broken but the phone is coming on , only i cant flash it at all , p.s it does not do any ui settings as well could this be a fault of the phone? |
07-03-2006, 11:34 | #6 (permalink) | |
Member: 1269 Status: Offline Thanks Meter: 485 | Quote:
if u have another phone u can check when u press connect in ufs did u choose dct4 then press check button u can then see if it connect to phone or not if u have another phone u can do the same test also to check narry | |
07-03-2006, 19:18 | #11 (permalink) |
No Life Poster Join Date: Sep 2005
Member: 183976 Status: Offline Thanks Meter: 134 | try to open your phone and take the motherboard of the phone and ajust the cable on it directly , that will work , i try this so many times and it work fine , but u must ajust the pins of the cable n there places of the motherboard ... but why u r choosing rh-38 for 1100 choose rh-18 !!!! |
07-03-2006, 19:37 | #12 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Dhuri
Member: 230164 Status: Offline Sonork: 100.1592997 Thanks Meter: 110 | Hello Neo Select Mcu And Ppm Files Then Click To Flash. Now Press On/off Butten To Phone. Some Time Set Boots With On/off Switch. Good Luck.......... |
07-04-2006, 09:17 | #13 (permalink) |
Member: 66075 Status: Offline Thanks Meter: 2 | thanx all for trying , it was a hardware fault with the phone itself , i opened the phone manually and saw a resistor missing which is normally situated very close to the to flash i.c which the cable connects through also it seemed that whomever did this , had also damaged the pcb. thanx to all who tried to help i really appreciate the effort wbr Neo |
Nokia 1100 not charging , help with pic plz | emchido | Nokia Hardware & Hardware Repair | 5 | 03-23-2009 20:13 |
6610 can erase but can not flash help!! | NuengEve | UFS2 + UFS3-Tornadoflasher | 1 | 03-07-2005 19:14 |
1100 not flash for griffin | abdoulaye | Griffin | 13 | 03-26-2004 08:34 |
Griffin - not flashing??? help me guys | dave007 | Griffin | 0 | 01-06-2004 23:06 |
Dejan box did not flashing - HELP! :-( | uu1dx | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 02-22-2002 12:43 |
