06-01-2007, 19:14 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: sarcelles Age: 47
Member: 161061 Status: Offline Thanks Meter: 568 | probleme with upgrade hwk ---------- HWK Update Client v 2.0.5.0 ---------- ---------- HWK upgrade started:20:06:03 ---------- -- Target Id : 62 CF 1 7 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.6 (c) SarasSoft 2005. -- UFSx S/N : /////// -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: TORNADO -- HWK ID : A1.04-PRO1-07C4BA4D01........... -- HWK Status : 1, DL: 0 ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Server reported error:No more upgrade logs. Last edited by ::. zine .::; 06-02-2007 at 16:57. |
06-01-2007, 20:59 | #3 (permalink) | ||
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
contact ur reseller... or wait for 24 hours... Quote:
i think no... he must contact his reseller...and they can solve the pb.. | ||
06-02-2007, 12:03 | #8 (permalink) |
No Life Poster Join Date: Mar 2005 Location: cebu city
Member: 126086 Status: Offline Sonork: 100.113901 Thanks Meter: 232 | contact your resseler about that matter... NOTE: Vista (tm) Users -------------------------------------------------------------------------------- M1cr0$oft have deemed that any executable should not have write access in the programs areas, there are two ways to get around this issue/security:- 1. Right click the application shortcut and select run as administrator 2. Disable UAC (User Access Control), I will not give info here how to do this, but G00gle is your freind, if you really really really want to do this, but remember this was added for a reason, disabling UAC gives all programs rights to everywhere. Odia. NOTE: To all Distributers and Resellers -------------------------------------------------------------------------------- Please do not update your HWKs to the latest version using the update client released on the 27/01/2007, as the UFS+HWK are now paired. This means the HWK will only work in the UFS it was updated in. If you have already performed this action, the solution is simple, make a record of the HIDs:- 1. if you are a distributer send the list of HIDs to Saras and ask them to be enabled for one more log 2. if you are a reseller send the list of HIDs to your distributer, who can then pass them onto Saras. REQ->FBI Process - Box Auth Error 20 -------------------------------------------------------------------------------- DO NOT, perform this process unless you have Box Auth Error 20, or you are advised to do so. 1. Run the update client. 2. Select your language. 3. Click "Next". 4. Wait until the "Update UFS Firmware" button is enabled and then click it. 5. Select req.fbi file, you will need to get this file from the support area. 6. After a few seconds the process will complete and create a file called xxxxxx.req. (where xxxxxx is your UFS serial number) 7. Send this file to your reseller. 8. When you receive xxxxxx.fbi from your reseller, perform steps 1-4 above. 9. Select xxxxxx.fbi 10. After a few seconds your box will be authorised. Your reseller is the only person who can help with this process, do not ask here in the forum, we will not generate xxxxxx.fbi files for you. NOTES:- 1. the xxxxxx.fbi file sent by your reseller is one time use only. 2. once you have made the xxxxxx.req file, do not perform any other steps on the box, since this will cause the xxxxxx.fbi file to be out of sync. HWK Upgrade Client FAQ -------------------------------------------------------------------------------- General notes: - Itv is better not to use Win98 to upgrade HWK module. Please use Win2k/XP only because Upgrade client was developed for these OS'es - Old UFS and HWK software versions will not work after HWK module, new software versions will also not work with not updated HWK module - Please disable all antivirus and firewall softwares before upgrade - Before running upgrade client it is recommended to set screen resolution to not less than 1024x768 and font size to Normal - NEVER publish your UFS and HWK serial numbers on forum - Please pay attention to the message, that is shown by software at the end of upgrade procedure. If it is - "Update successful, use Client again to authorize HWK", you should run upgrade client again to authorize your HWK module (actually - repeat operation). Error messages: 1. HWK SD REPAIR ERROR: xxxxx HWK upgrade error. This error occures when HWK was affected by third-party tools before upgrade or your HWK is a clone. Please don't contact anyone, it's your own stupid fault. 2. Your account is suspended. Please contact your reseller! Your account is blocked by administrator. Please contact your reseller You need to provide your reseller at least the following information: - The date and invoice number of your HWK purchase - Full log given to you by upgrade client 3. No more upgrade logs. HWK module with this serial number was already upgraded. If you already upgraded your HWK, you need not to upgrade it again until directed. If you haven't tried to upgrade it yet, get this error on upgrade and cannot run latest software versions, please contact your reseller You need to provide your reseller at least the following information: - The date and invoice number of your HWK purchase - Full log given to you by upgrade client 4. Server is going to shutdown. Please try update in 20 minutes. Server is being stopped by administrator. Please try upgrade process again in 20 mins. 5. Account for this HWK module does not exist on server. Please contact your reseller! Account for HWK number with this serial does not exist on server. Please contact your reseller. You need to provide your reseller at least the following information: - The date and invoice number of your HWK purchase - Full log given to you by upgrade client 6. Authorization failed! Are you using the latest HWK Upgrade client software version? Server authorization error. Please ensure you are using the latest UFS suite and upgrade client software versions 7. Your account was closed by the server administrator. Please contact your reseller! Your account on server was closed by administrator. Please contact your reseller You need to provide your reseller at least the following information: - The date and invoice number of your HWK purchase - Full log given to you by upgrade client 8. Error: Your update client version is expired! Please download new client from the support area and start the upgrade again. Download new upgrade client from support area and try upgrading your HWK module with it. 9. Error upgrading applets: HWK UPDATE ERROR: xxxxxx Hardware problem occured during upgrade process. Please contact your reseller. You need to provide your reseller at least the following information: - The date and invoice number of your HWK purchase - Full log given to you by upgrade client 10. Error connecting to ufs: hwk login error: xxxx Error establishing data transmission channel with HWK module. Please ensure your module is present and is correctly installed. If you are unable to solve the problem by yourself - please contact your reseller You need to provide your reseller at least the following information: - The date and invoice number of your HWK purchase - Full log given to you by upgrade client 11. Authentication stage error: Server reported error:Not translated! Please select English language om the software's welcome page and retry upgrade process. Now error message will be shown correctly 12. Connection to server failed: Socket Error # 10060 Connection to server failed: Socket Error # 10061 Connection refused. Please disable or uninstall all installed antivirus and firewall software and retry upgrade operation. If the error persists, please ensure, that your internet provider is not using firewall also 13. Authentication stage error: Socket Error # 10053 Software caused connection abort. General TCP/IP failture occured. Please disconnect from internet (having your modem switched off for example), wait for 5-7 minutes and connect to internet again and retry upgrade process. 14. Authentication stage error: Socket Error # 10054 Connection reset by peer. TCP/IP connection to server from your PC is unstable. Please try to connect to internet via different internet provider. If you have no such possibility, please try to perform upgrade process several times until you get positive result. 15. Connection Closed Gracefully. Connection to server was suddenly terminated. Please retry upgrade process a bit later or try to connect to the internet via another internet provider and retry the upgrade. P.S. - Please do not ask stupid questions in this thread. If it is said "contact your reseller" - really contact him first before posting anywhere - to "sweet free soft lovers" and cloned HWK module owners: I cannot activate anything, add anybody to anywhere, restore your HWK module or transmute water to wine. I am tired already of messages with questions about cloned modules restoration. -------------------------------------------------------------------------------- Last edited by Odia The Ultimate : 3rd Jul 2006 at 06:50 PM. http://forum.gsmhosting.com/vbb/showthread.php?t=370992 |
09-01-2013, 09:20 | #9 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2003 Location: gsmcity Age: 44
Member: 21296 Status: Offline Thanks Meter: 328 | Connection to server failed. Socket Error # 10061 How to update my HWK with the new control panel released? I am getting always the same error as below coded? Code: App: UFSx (HWK) Control Panel v 2.3.0.2 by SarasSoft CPU: GenuineIntel Platform: Windows NT 5.1 (Build 2600 Service Pack 3) Versions: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 C:\Program Files C:\Program Files\Common Files Nokia Path not Found, Set to: C:\Program Files\Nokia\Phoenix C:\Documents and Settings\user\Desktop C:\Documents and Settings\user\Start Menu\Programs App: UFSx (HWK) Control Panel v 2.3.0.2 by SarasSoft Box: 1 Location: 81 Serial: 71671 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 71671 HID: BAD6FC3A41600009, HWK: A1.04-PRO1 LIC: True HWK: NOT AUTHORISED, Update Box Bad IX: ABCD Failed: 2 Your IP: 46.99.128.25 Support: Account Ok Something Wrong, Try to Use [Update Box] Box: 1 Location: 81 Serial: 71671 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 71671 HID: BAD6FC3A41600009, HWK: A1.04-PRO1 LIC: True Your IP: 46.99.128.25 Support: Account Ok REST: Ok UFSx: UFS3 SarasSoft, USB S/N: 71671 NVML: Ok BOOT: UFxBoot V2.2 (c) SarasSoft 2003. CORE: UFS_USB V2.8 (c) SarasSoft 2007. SERN: 71671 LIC5: True BOXK: 0 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 71671 HID: BAD6FC3A41600009, HWK: A1.04-PRO1 LIC: True Connection to server failed. Socket Error # 10061 Connection refused.(No connection could be made because the target machine actively refused it.) |
09-02-2013, 06:14 | #11 (permalink) | |
No Life Poster Join Date: Feb 2007 Location: Upleta
Member: 449748 Status: Offline Thanks Meter: 162 | Quote:
ufs+hwk 2.3.0.2 last server update 20013-08-21 - Download - 4shared | |
09-02-2013, 11:23 | #12 (permalink) | |
Freak Poster Join Date: Jul 2013 Location: PKD
Member: 1987269 Status: Offline Thanks Meter: 190 | Quote:
hwk_support_suite_setup_v02.03.000 - Download - 4shared - boy 9440 Regards. | |
If you have a problem with your hwk (No more upgrade logs) post here !! | Supplier4unlock | HWK | 8 | 06-21-2008 06:05 |
problem with my hwk to upgrade | Momo_Gsm | HWK | 1 | 05-01-2008 19:12 |
Problem with upgrade orginal box!!!! | .:: SkyElectronic ::. | UFS2 + UFS3-Tornadoflasher | 0 | 03-15-2004 08:27 |
Problem with upgrading Alc 701 | dimon | Alcatel & TCL Old Models | 4 | 10-15-2003 07:03 |
