02-06-2005, 13:26 | #1 (permalink) |
Freak Poster Join Date: Jan 2002 Location: Finland Age: 52
Member: 8360 Status: Offline Thanks Meter: 4 | 9500 Phone lock. How clear ? Reset User lock not work for me . After all UI options reset lock stay in phone. I need flash phone ? I have this files: RA2_4441.352 RA2n4441.c01 RA2n4441.u01 RA2nxxxx.P01.pp What files i must use in: MCU.. PPM.. CNT.. ? UFS can flash 9500 phone without problems ? *Thanks about help |
02-12-2005, 22:11 | #9 (permalink) |
No Life Poster Join Date: Sep 2002 Location: max232 chip
Member: 16036 Status: Offline Thanks Meter: 5 | hi no1 really ANYSWERED anno ? about files to select to flash phone n weather at this point its safe to flash the phone i have also tryed to factory reset n default user code BUT failed i get 2nd boot arror any help advice will be appreciated thanks alot |
02-13-2005, 02:45 | #11 (permalink) | |
Junior Member Join Date: Nov 2004 Age: 43
Member: 92755 Status: Offline Thanks Meter: 0 | Quote:
1-init sim locks 2-full factory defaults 3-change into normal mode 4-format user area try again if error occured if no result try to flash it 1-ur mcu r (RA2n4441.c01) 2-ur ppm r(RA2n4441.l03) 3-ur cnt r(RA2n4441.u03) Last edited by midolotfy2010; 02-13-2005 at 02:56. | |
02-13-2005, 11:05 | #12 (permalink) |
Member: 16036 Status: Offline Thanks Meter: 5 | hi man flashing problem error when i select 1-ur mcu r (RA2n4441.c01) <<<-- i get error"NOTHING TO FLASH" if i select Ra2_4441.352 i get this error then : 1st Boot Ok, ORCA, UPP: 1130 Fl0: 0x01000000-0x013FFFFF,00012A7E,Amd 29BDS320 Algorithm: m_amd.fia Algorithm Ok, MSID: 842FEE85175F8156E18B967A02 Decoded MSID: 3E4EBAE9-005DA9C0-A8000000 Encoded FAID: 52CFD751-D19E4C13-A12C0CF9 Erasing: 0x01000000-0x0100FFFF ... Erasing Error: 10, at: 0x01000000-0x0100FFFF, 94050F, Time: 00:12 Process Failed, Repowering Mobile any idea what to do next thanks alot |
02-13-2005, 11:41 | #13 (permalink) |
Member: 8360 Status: Offline Thanks Meter: 4 | STOMATELA : "after reset user lock type full factory defaults " No helped for me, phone lock stay in phone I can't unlock phone code with ufs without flash firmware update. |
02-13-2005, 12:13 | #15 (permalink) |
No Life Poster Join Date: Nov 2003 Location: 00000000h Age: 42
Member: 43548 Status: Offline Thanks Meter: 2,192 | Yes UFS only support Partial Flashing 9500, not PDA part. Also the initSimlocks & Reset UserLock (on some versions) with UFS cant Reset the security code... @ anno Please Try this... Read PM area start 20 to 40... Open PM Files using notepad... Find Record /Section 35, key 0... U will get 7 bytes-->the defaults : 31323334350000 Just remove the chr 3, and u'll get: 123450000 the security code for this the first 5 digit--> 12345 Tested 100% working by me on some DCT4 & WD2 phone.. Please try it, post ur Result here... |
lg ke750(*****) phone lock how removed | arunamobile | ULT PRO | 5 | 07-03-2008 13:44 |
k610i phone lock how ? | patric | Cruiser Suite | 3 | 03-09-2007 03:17 |
Toshiba Phone Lock! How to Disable? | theonlyallan | FuriousGold | 3 | 07-31-2006 11:45 |
sgh2400 with phone lock .. how repair ? | Kilowat | VLSI, Conexant, Skyworks and Old Models | 3 | 02-05-2002 23:21 |
